Old 05-05-2006, 06:55 PM   #181
i was thinking about your database last night and i thought it would be a good idea to eventually have a list of all the parts in alphabetical order with the part numbers and weights. Then instead of everyone looking in their instruction manual for the part numbers you can see them on your database in a seperate section to the UE/X.........just an idea for the future
ae_ntc3 is offline   Reply With Quote
Old 05-05-2006, 07:58 PM   #182
rmdhawaii's Avatar
Thanks for the suggestion. What you see on the Web page right now is just a quick and dirty version so that people can look it over and come up with more suggetions. When the final spec gets published, it will be much more organized and documented than how it's presented now. I'll send you an advanced preview when it's ready so that you can provide some feedback.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-05-2006, 11:40 PM   #183
Team Kamikaze's Avatar
Originally Posted by Sparx
I dont know if i got a bad example of the KFactory brake disc, but mine differs about 0.15 mm in thickness resulting in pulsing brake. Also it fits very poorly with the brake hub since the hole is too big.
The glued brake pads is awsome though combined with the standard disc.
Check your brake shaft pretty sure it is bent causing pulsation if not the K factory brake set is one of the best
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-06-2006, 10:28 AM   #184
fritzD's Avatar
Send a message via Yahoo to fritzD
rmdhawaii,
great job on this thread ang website.... very very informative... keep it up!
fritzD is offline   Reply With Quote
Old 05-08-2006, 02:29 PM   #185
rmdhawaii's Avatar
Since I have to order two sets of spur and pinons for my car anyway , I decided to order the Ultimate Edition parts, with the exception of the pinon gears I don't use and the APP brakes (I'm going with the K Factory disc and pads). The parts will be here in about a week, but I probably won't be running the Ultimate X until June.
Originally Posted by fritzD
rmdhawaii,
Thanks! Appreciate the feedback.
Old 05-08-2006, 02:56 PM   #186
jag
jag's Avatar
I guess someone dropped some money this weekend.
jag is offline   Reply With Quote
Old 05-08-2006, 03:05 PM   #187
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default results
Since I have to order two sets of spur and pinons for my car anyway , I decided to order the Ultimate Edition parts, with the exception of the pinon gears I don't use and the APP brakes (I'm going with the K Factory disc and pads). The parts will be here in about a week, but I probably won't be running the Ultimate X until June. Thanks! Appreciate the feedback. [/I]
I BEGIN RACING THE PROSERIES IN 2 WEEKS WILL SEE HOW IT TURNS OUT
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-08-2006, 05:19 PM   #188
robert maestrey's Avatar
great choice on the disc and pads they are very good...thats what i use
robert maestrey is offline   Reply With Quote
Old 05-08-2006, 07:28 PM   #189
dodo's Avatar
Send a message via Yahoo to dodo
rmdhawaii,
hey my name is in the website as well !!!
surprised to see that, thanks
well to be honest i haven't touch my RRR in 6 months since i play EP at the moment (and since i BROKE my 2 race old evo 2 engine). Interesting to see that a lot of us participate in creating the 'ultimate' RRR.
Not sure if anyone pointed this out, but it helps to change the screw that links the rear upper camber link to the rear hub to a longer one. I broke a lot of rear hubs during my first few runs with RRR, improper settings etc might result in spin and if the rear hub hit something it may easily be broken along the area where the screw is.
But it doesn't happen anymore since i change it to longer screw, can't remember whether it's 3x20 or 3x25mm screw.
hope this helps and can be included as one of the 'minor but helpful' tips for new RRR owners
dodo is offline   Reply With Quote
Old 05-08-2006, 07:47 PM   #190
thats what ive ordered too but it still hasnt got here and my first race with the rrrX is 4days!!!
Old 05-08-2006, 07:49 PM   #191
ohh rmd add this to the database:
kawahara front layshaft mount (k-475)
the quality is superb and its not as flimsy as the stocker so there is less lateral movement on the shaft and better drivetrain efficiency.
Old 05-10-2006, 06:35 AM   #192
rmdhawaii's Avatar
The "best pricing" cost estimate for the current Ultimate Edition spec is approximately $162.45 USD, +/- $5.00 USD.
Kyosho VSW043 : 3D Lightweight Flywheel
Kyosho VZW215-15 : 1st Gear, 15T, 16T or 17T steel
Kyosho VZW215-16 : 2nd Gear, 20T, 21T, 22T or 23T, steel
Kyosho VZW213 : Lightweight Clutch Bell
Kyosho VZW063 : Aluminum Brake Lever
Kyosho VZW209 : Titanium 2-Speed Shaft
Kyosho VZW211 : Titanium Bevel Shafts for the Rear Diff
Kyosho VZW214 : Special Main Chassis 3T/7075 for V-ONE RRR
Kyosho APP02 : APP Brake Rotor & Pad Set
Kyosho VZW207 : Rear Shock Stay for V1RRR
Note: This includes only one set of 1st and 2nd pinion gears - not all seven gears.
Old 05-10-2006, 06:50 AM   #193
maskedrider's Avatar
does the Alum pulleys works better then the plastic stocks pulleys ??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-10-2006, 07:37 AM   #194
jag
jag's Avatar
I don't think they work better but they should last longer. The plastic are lighter.
Old 05-10-2006, 02:00 PM   #195
They tend to strip belts easier than the plastics.....my 2 cents...jag are they really heavier? that would be another reason not to use them.
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
