Kyosho V-ONE RRR Ultimate Edition (UE) >
Old 05-02-2006, 08:41 AM
  #151
SOLOARTIST 702's Avatar
Default CAR
ive also changed my tie rod ends from ball cups on the outside to swivel ball ends just because . i will also add pics to the sight when i figure out how to
SOLOARTIST 702 is offline
Old 05-02-2006, 01:13 PM
  #152
dougday's Avatar
Originally Posted by rmdhawaii
Since Will (aka Soloartist) wanted to start building the UE for some upcoming races, I couldn't resist helping him out. So here is a very preliminary spec. It still needs more input (including mine), feedback and testing, but it's getting there.
http://www.nitrokb.com/vonerrr/UltimateEdition.html
The bottom line: If your engine, clutch, 2-speed, tires and setup isn't right, these parts are not going to help you whatsoever. Driving is also a major factor. If you bolt these on and don't see any improvement, let's see if we can figure out what's going on with your car.
Some helpful information will include:
- Full non-kit parts list, including engine, glow plug, fuel, body, tires, etc.
- Setup information
- Track conditions, weather, temperature, etc.
- Your full race results, including qualifiers
- A-Main full race results, including qualifiers
- Your impressions of how the car is performing on the track
Good luck!
RMD, you left the following hardened gears out of the list
VZW066-20 20T
VZW066-21 21T
VZW066-22T 22T
VZW066-23T 23T
dougday is offline
Old 05-02-2006, 01:45 PM
  #153
rmdhawaii's Avatar
VZW066-20 20T
VZW066-21 21T
VZW066-22T 22T
VZW066-23T 23T
Thanks for catching that.
rmdhawaii is offline
Old 05-02-2006, 04:58 PM
  #154
Default GEARS
yeah i also need to get all the hardened gears
Old 05-02-2006, 05:08 PM
  #155
Default set up
MY 2 CENTS remember to get a set up that is for you you cant use someone elses most of the time and be succesful i use to do that & it never worked until i got my own set up and thing are alot better no A main yet but better direction A PENNY FOR MY THOUGHT
Old 05-03-2006, 02:22 AM
  #156
Team-RTR's Avatar
what can you guys reccomend as an upgrade for the rear outdrives??
Team-RTR is offline
Old 05-03-2006, 03:51 AM
  #157
the lightweight skyline rear outdrives are pretty good
ae_ntc3 is offline
Old 05-03-2006, 04:41 AM
  #158
rmdhawaii's Avatar
Could you be a little more specific please? How do they compare to the stock ones? Do they wear better? Do you like the fact that you can rotate them 90 degrees and get twice the mileage out of them?
http://www.skylinercracing.com/store/P_76.htm
I wonder if any of the sponsored Skyline drivers are using them?
Old 05-03-2006, 07:53 AM
  #159
[quote]what can you guys reccomend as an upgrade for the rear outdrives??[quote]
add these to the skyline outdrives and you will have no rear end issues
http://www.phenixdist.com/index.asp?...ROD&ProdID=659
Motorman2 is offline
Old 05-03-2006, 07:57 AM
  #160
Default univ.
[QUOTE=Motorman2][quote]what can you guys reccomend as an upgrade for the rear outdrives??
those look awfully nice im putting those on my list
Old 05-03-2006, 08:01 AM
  #161
since we changed to the super hard st steel axle materials I have not heard of a single soul breaking one. On any car
The G4 st steel fronts fit the RRR to
Old 05-03-2006, 02:48 PM
  #162
dougday's Avatar
RMD,
The following option parts are worth considering as well
VZW206-18 Aluminum Pulley(RRR/18T/1pc)
VZW206-21 Aluminum Pulley(RRR/21T/1pc)
VZW206-23 Aluminium Pulley(RRR/23T/1pc)
VZW206-24 Aluminum Pulley(RRR/24T/1pc)
VZW206-27 Aluminum Pulley(RRR/27T/1pc)
Especially the 21T for the mainshaft as the plastic pulley wears fairly quickly.
dougday is offline
Old 05-03-2006, 04:36 PM
  #163
rmdhawaii's Avatar
RMD,
There were some posts suggesting that the some metal pulleys (not necessarily Kyosho's) have a tendency of eating up the belts. Have you had any problems at all?
Anyone else tried running or is running aluminum pulleys?
Old 05-03-2006, 04:47 PM
  #164
Racing4Evo's Avatar
Regarding rear outdrives:
The stock outdrives are very soft. If you are looking for a readily available alternative the rear outdrives for the MTX-4 are a direct fit. These last around 3 times longer but they still wear out. The best thing I have tried so far is the Hardened Lightweight outdrives from Skyline Racing. I put on a set when my stock Mugen outdrives wore out and they haven't shown any wear yet, and like mentioned earlier, you can rotate the outdrive for a fresh outdrive slot.
If you consider the stock outdrives okay then the Mugen's are great and on top of that the Skyline outdrives are bullet proof.
Racing4Evo is offline
Old 05-03-2006, 04:51 PM
  #165
Racing4Evo's Avatar
Also, I think everyone should get the new brake pulley adaptor from the V-One RRR Evo for their car if it fits or upgrade the entire transmission if needed. I've broken the stock plastic pulley twice and both times it was very hard to diagnose the problem. The car will behave like it has no rear traction and will over rotate in the corner. Only after rebuilding the entire rear end did I find the broken pulley.
