Engine for G4S >
Engine for G4S
Engine for G4S
Old 04-29-2006, 08:17 AM
  #31
itchy b's Avatar
Originally Posted by nitrobeast
You might have a faster car but doesnt mean you will be faster around the track.
i wouldnt be worried about lack of power from your v12, it should go just as well as the os run her in and enjoy the tyre frying what happened to getting the os 18 ??
itchy b is offline
Old 05-04-2006, 03:20 PM
  #32
nitrobeast's Avatar
Trader Rating: 44 (100%+)
I have had a couple of OS motors and wanted to try something else out. I might pick up the OS next.
nitrobeast is offline
Old 05-05-2006, 12:51 AM
  #33
itchy b's Avatar
i just about have 6-7 tanks go throuth the tz and i'm impressed with the bang for buck it has, i think it goes better than my nsr jp that i had and it still has more left to give! its my first os but i don't think it will be my last
have you ran your new g4s with rb, and if so how do you rate it?
itchy b is offline
Old 05-05-2006, 03:31 PM
  #34
nitrobeast's Avatar
Yeah OS makes a good motor for the money they cost.
As for the RB i hated it the first day, it had me . I had a problem with it because it was getting way to hot way to fast at idle. I figured it had a air leak. After i check for air leaks and didnt find any i decided to see how many turns the low speed needle was set at. It was only set to 2.5 turns while the spec said it was 5. I guess you can say i learned a leason and to check next time. That explained a lot as to why i couldnt let it idle for more then a minute. I also have about 6 tanks throught it now and she has some punch.
If i open it up half way while turning i cant keep it straight and it is very rich still. It looks like when all said and done she should be quick.
As for the G4S i love it 2. The car is very smooth.
Old 05-24-2006, 05:27 AM
  #35
uniquexme's Avatar
guys, yet to get the G4S, but sure will, coz now considering on the engine. here is my list of engine, do tell me where can i get and how was it with G4S
1. RBV12 5-port Tuned Rody
2. Max MX12 S5 / SL5
3. OSSpeed Max 12TZ
its seems that OSSpeed engine is really really hard to find. also i would like to know more about engine, may i know where can i find that engine pls?
uniquexme is offline
Old 05-24-2006, 08:48 AM
  #36
Sirio STI
Motorman2 is offline
Old 05-24-2006, 10:46 AM
  #37
razzor's Avatar
Any body using AxeMotorRossi 173R12 X3 or Palmaris Profi PR12 ???
razzor is offline
Old 05-26-2006, 08:15 PM
  #38
British Menace's Avatar
Default Accel' & top speed
Tune your clutch to get the acceleration,
I would suggest orange clutch spring (1.7mm) and 0.65mm tension on the spring.
Then you can try going to:
19/50 First
25/45 Second.
The clutch is just the best so, presuming you have the motor to pull it, the clutch will give you excelent acceleration and you'll be right up there on top speed beleive me.
Best of luck.
Tony
British Menace is offline
