Fuel mileage?? >
Fuel mileage??
Fuel mileage??
Old 06-23-2022, 02:23 AM
Default Fuel mileage??
Hi guys, im running a 220mm converted 733 with 2009 353 engine, 2660 pipe and shortest conical manifold. Having a blast, but i could use some more speed, the very fastest touring car guys are about 2 seconds a lap faster than me, 16 versus my 18seconds a lap. One thing ive noticed though is they struggle to make 5 mins on their fuel, running out ocassionally on the cool down lap etc. Hoewever i can easily make minutes maybe even slightly more (i refuel at 6 mins). Anyone any ideas why theyre using so much more fuel? I have removed the venturi restricter and put on the lowest pinions available too.
thanks for any help
coupehdi is offline
Old 06-23-2022, 03:12 AM
fyrstormer's Avatar
Is there any chance you're running slightly lean in an attempt to go as fast as they are, and actually making less power in the process? Aside from that, there are several parameters that could be adjusted inside your engine to improve its power output, but it's not something that can be explained in a how-to list of steps. 2-stroke engine tuning and modification is very much a hands-on, trial-and-error activity.
Also, depending on the track layout, running the smallest pinion gears may not actually make you faster. It depends on whether you're falling behind when accelerating out of corners, or when sprinting down the straightaways.
fyrstormer is offline
Old 06-23-2022, 03:36 AM
the rc guy's Avatar
running a small pinion will never make a rc faster. running a larger one will. that's basic knowledge.
the rc guy is offline
Old 06-23-2022, 03:41 AM
Roelof's Avatar
Easy....
Back in those days a 5 minite qualfy needed to be reached if you do not want a fuel stop. In the last years thanks to the ENS many organisations switched to a 4 minute qualify with which the engines could be configured (timed) faster.
Roelof is offline
Old 06-23-2022, 05:20 AM
I know using smaller pinions gives less top speed lol, i was doing it cause i thought perhaps i was overgeared before. Ya could be onto something with the timing though. Perhaps i could shim up the liner very very slightly to increase timing and power since i easily make the distance for fuel.
coupehdi is offline
Old 06-23-2022, 10:24 AM
Running smaller pinions will give you less mileage actually. With smaller pinions the engine is at higher RPMs more of the time, using more fuel.
The 2s deficit is probably because they're driving faster than you, and that would makes sense of their fuel mileage. Concentrate on your driving, get a setup that you can drive and just practice. Eventually you will get closer.
nitrodude is offline
Old 06-23-2022, 02:28 PM
Fuel mileage is a very complicted issue that will involve all parameters: wind, humidity, body drag coefficient, gas quality/oil content, engine condition/tune, drivetrain weight/efficiency, gear quality, tire size/wear rate/drag, driving positions while racing, trigger finger habits, clutch setup, etc.....The list goes on and on...
bertrandsv87 is offline
