Old 12-20-2002, 05:41 PM   #1
Integy or Hudy setup system?
which is the best bang for the buck in the long run?
freestyle is offline   Reply With Quote
Old 12-20-2002, 06:17 PM   #2
modellor's Avatar
Definately the Integy Set. It is made of alloy and its a fraction the price of the Hudy Set which is plastic. The markings on the Hudy set also wear off and setting up can become rather hard.
modellor is offline   Reply With Quote
Old 12-20-2002, 06:47 PM   #3
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Integy = $40
Hudy = $100
Integy does camber, caster, toe, is easy to read, easy to set up, works on a limited number of cars (all 1/10th scale cars - no 1/8th)
Hudy does camber, caster, toe, is harder for ME to read, easy to set up, has models for all kinds of cars.
Bang for buck - Integy. I like mine TONS. I have a Hudy too and I don't know where I put it!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-20-2002, 07:26 PM   #4
patelladragger's Avatar
Send a message via AIM to patelladragger
integy hands down. So much easier to read and quality too, 10 dollar carrying case for it is especially handy.
patelladragger is offline   Reply With Quote
Old 12-20-2002, 07:33 PM   #5
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Hey Freestyle - Did I talk to you earlier tonight?
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-20-2002, 07:38 PM   #6
TSR6,
no we did not talk
Old 12-20-2002, 07:41 PM   #7
popsracer's Avatar
Default Carrying case
Where did you get the case? Do they have them listed on the Integy site yet?
Thanks,
popsracer is offline   Reply With Quote
Old 12-20-2002, 07:43 PM   #8
I just checked the Integy site, they have the cases listed. The setup kits now come with the case too.
Cool, thanks all for the responses. I'll get the Integy one. One more question though. What about droop gauges and ride height gauges? Are they a must have, and if so, any brand will do?
Old 12-20-2002, 07:53 PM   #9
ride height gauge is very important i like the ones that are shaped like a triangle not steped this allows a more accurate measurement i dont use droop gauges much but i suppose they could be important
jason102276 is offline   Reply With Quote
Old 12-20-2002, 08:05 PM   #10
popsracer's Avatar
Default Don't need seperate Droop Gauge
Guys;
The easiest way to set Droop is with a Ride Height gauge. Just push it under the chassis futher until the Tires just clear the set-up board (paper thickness), then read the gauge again. The difference between the ride Height and what you just measured is the Droop. Way too easy.
A WIDE [3/4-1"] gauge makes it easier to check as it keeps the chassis a little more stable from side to side.
Old 12-20-2002, 08:08 PM   #11
is a "down travel gauge" the same as a "droop gauge"?
edit: thanks for the tip PopsRacer, i missed it first time around.
Old 12-20-2002, 08:09 PM   #12
i never thought to do it that way very clever i may now begin to actually measure it usually i just set shock length and leave it alone cause im lazy
***Integy Tire Truer/Hudy 1/10th setup gauges/Integy Charger F/S*** HarKonnenD R/C Items: For Sale/Trade 40 09-25-2008 10:17 PM
Wanted : Integy / Hudy Setup system for 1/10 touring Tag R/C Items: Wanted to Buy 2 01-07-2006 12:55 AM
Integy, Hudy setup. Hudy truer. Airtronics servo. 1/12th foams Scott Fisher R/C Items: For Sale/Trade 10 10-27-2005 08:35 PM
Hudy Setup System and Digital Weight Monitoring System racer rich R/C Items: For Sale/Trade 16 02-23-2005 07:56 AM
FT: Hudy MP 5 or 6 setup system for touring car setup system AQuionIV R/C Items: For Sale/Trade 1 05-30-2004 02:08 AM
