Capricorn LAB C804 >
Capricorn LAB C804
Like Tree14Likes
Capricorn LAB C804
Old 05-10-2021, 01:00 PM
BigC2007's Avatar
Default Capricorn LAB C804
Hey Gents any reviews or feedback on the Capricorn LAB C804 ? I haven't heard to much about them in the states ( US) but would like to know more about this kit and also are parts hard to get ?
BigC2007 is offline
Old 05-10-2021, 01:14 PM
Great car! I've really enjoyed running the car this year. I really like the design. Maintenance is pretty easy and straightforward. Reliability and durability has been very good. Parts and support from rctarget.com in the US.
Robert Ronas is offline
Old 05-10-2021, 01:24 PM
BigC2007's Avatar
Thanks Robert for the reply.
BigC2007 is offline
Old 05-10-2021, 05:32 PM
Bundy_Bear's Avatar
C804SL is a great car... and RCTarget are good to deal with as are RC-Netshop.
Bundy_Bear is offline
Old 05-10-2021, 05:51 PM
BigC2007's Avatar
Thanks Bundy
BigC2007 is offline
Old 05-11-2021, 08:31 AM
blackshark3's Avatar
I prefer my 804 than my IF18 and as I feel the 804 has more on power steering. Also as the 804 uses bigger 21mm bearings on 4 corners it lessen the interval of bearing changes than the IF18 or previously my MRX6R. However, space for pipe/manifold on the 804 is a bit finicky, as I found some pipe/manifold combination (e.g Nova 2015 with the longer pipe mount tip with the Nova 41014 manifold) would have the tip of the pipe touching the steering plate, but the same combo would not have the same problem on the other cars.
1/8 IC Fan likes this.
blackshark3 is offline
Old 05-11-2021, 10:10 AM
BigC2007's Avatar
Good info
BigC2007 is offline
Old 05-11-2021, 10:11 AM
BigC2007's Avatar
Is the latest version of the cavicorn the C804SL ? if so what was the upgrade to the before the SL ?
BigC2007 is offline
Old 05-11-2021, 03:51 PM
Bundy_Bear's Avatar
Have this issue with OS and ONE pipe/manifold. Did wonder if optional OS M03 header may make it easier. The precision hubs is a nice option part too with bearing sitting in an aluminium insert. Bearings are smaller than standard setup too.
Old 05-11-2021, 07:02 PM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
So Big-C did you order one yet from RC target?
1/8 IC Fan is offline
Old 05-11-2021, 07:36 PM
Trader Rating: 80 (100%+)
I have 2 ,best car I have had in a long time.Very easy to drive and set up as well.Steering is great ,clutch is the bomb
martind1318 is online now
Old 05-12-2021, 05:45 AM
BigC2007's Avatar
It will be this or the ARC just waiting to pull the trigger. Also RC target is out of stock.
BigC2007 is offline
BigC2007's Avatar
Thanks Martin
BigC2007 is offline
Old 05-12-2021, 06:55 AM
BigC2007's Avatar
Hey Martin how is the C804 vs MRX6r or X ?
BigC2007 is offline
Old 05-12-2021, 08:52 AM
I believe RC Target should be getting cars soon. Call them to make sure.
BigC2007 likes this.
