Capricorn LAB C804 >
Capricorn LAB C804
Like Tree14Likes
Capricorn LAB C804
Old 10-05-2021, 06:36 AM
  #76
BigC2007's Avatar
Originally Posted by Robert Ronas View Post
Hey Clint. That's the correct number.
Here's a spring chart.
Thanks Robert
BigC2007 is offline
Old 10-05-2021, 06:37 AM
  #77
BigC2007's Avatar
Originally Posted by Cant drive View Post
The springs in the kit are the red springs? So I don’t think you need to purchase them
Your right I just need to buy some yellow fronts.
BigC2007 is offline
Old 11-08-2021, 07:23 AM
  #78
BigC2007's Avatar
Originally Posted by xtremes View Post
At Steel City we've been using :
Front: yellow springs, 500 oil, 2 holes, 5 mm ride height, 2.0 mm downstop, 66 mm tire diameter, 32 compound, 1 deg. toe out, 1 deg camber, upper arm hinch pin all the way up and in, no stiffining radio deck plate. Long wheelbase, 252 mm track width
REAR: red springs, 600 oil, 3 holes, 6mm ride height, 9mm downstop, 73mm tire diameter, 35 compound, 2 degree toe in, 2.5 camber, everything else stock. 262 mm track width, *Capricorn tires
Enjoy it !
xtremes just wanted to thank you for sending me the set up information for Steel City ....... I final had a chance to set my 804sl up to this set up and oh my goodness !!!! the car was on rails and made me look really good my lap times was the best I have had and keep on getting lower, Again thank you !
Robert Ronas likes this.
BigC2007 is offline
Old 11-09-2021, 04:05 PM
  #79
xtremes's Avatar
I'm glad the info I gave you was helpful ! My pleasure !
xtremes is offline
Old 11-23-2021, 10:33 AM
  #80
BigC2007's Avatar
Anyone know what size turnbuckle wrenches to get for this kit ?
BigC2007 is offline
Old 11-24-2021, 05:09 PM
  #81
4mm for the tie rods.
Robert Ronas is offline
Old 11-28-2021, 01:51 PM
  #82
BigC2007's Avatar
Thank you
BigC2007 is offline
Old 01-06-2022, 07:59 AM
  #83
BigC2007's Avatar
Someone mention that a Capricorn 805 may be coming out, does anyone have any info on this ?
BigC2007 is offline
Old 01-06-2022, 08:33 PM
  #84
Bundy_Bear's Avatar
If it is in the works will be hush hush until teaser cad drawings are released too RedRC.
Bundy_Bear is offline
