Capricorn LAB C804
#61
#62
About time I finish this car !!!
#64
#65
OS break in Steel City Fontana
#66
Capricorn experts I need some help. I have the 803 evo with the original steel rear swing shafts(dogbones) and Capricorn no longer makes the steel ones and I just tried the aluminum replacement and they snapped. Does anyone have the original #2232 steel rear swing shafts they would sell me or has anyone converted the rear of their 803 to the swing shaft design like the 804 ? Any help appreciated
thanks
idbdoug
thanks
idbdoug
#67
Hey Gents
For those of you that have race at Steel City which is a high bit track on a non windy or dirty day, Which of the following are you using ?
Springs front and back ?
Shock oil ?
ride height front and back ?
Toe in/out front and back ?
Thanks for any info.
Shock oil ?
#68
Front: yellow springs, 500 oil, 2 holes, 5 mm ride height, 2.0 mm downstop, 66 mm tire diameter, 32 compound, 1 deg. toe out, 1 deg camber, upper arm hinch pin all the way up and in, no stiffining radio deck plate. Long wheelbase, 252 mm track width
REAR: red springs, 600 oil, 3 holes, 6mm ride height, 9mm downstop, 73mm tire diameter, 35 compound, 2 degree toe in, 2.5 camber, everything else stock. 262 mm track width, *Capricorn tires
Enjoy it !
#69
At Steel City we've been using :
Enjoy it !
Enjoy it !
#70
Anyone know the part # for the rear RED springs ? I did not see them on RC Target
#71
#73
#75
The springs in the kit are the red springs? So I don’t think you need to purchase them
