Old 03-31-2006, 03:02 PM   #1
Default 1/8 onroad bearings question
Just got a new MRX4. This is my first 1/8 kit, so I am wondering what
is a good practice to reduce drag. Do you clean up the greese
in the bearings with motorspray and then use thinner bearing oil?
Like you would do with the electrics?
Any other tips are appreciated.
powerdrifter is offline   Reply With Quote
Old 03-31-2006, 03:54 PM   #2
Mugen bearings are notorious for spewing out all the grease after the first few runs. Run them as is and you will be fine. When it's time for replacements, go for Acer Ceramics. The hold up much better, especially at the front and rear hubs.
Tony Vega is offline   Reply With Quote
Old 03-31-2006, 10:08 PM   #3
i do all the above plus i remove the dust shield on the side of the bearing that faces inward.
sedanaddict is offline   Reply With Quote
Thundershot Bearings question? skytrooper Electric On-Road 14 12-05-2007 08:47 AM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Question about installing bearings oMONSTERo Electric Off-Road 25 04-29-2005 09:11 AM
Question about Tamiya Mini Cooper Bearings rctoyguy Electric On-Road 5 07-26-2004 12:01 AM
Question on Ceramic Bearings J Smith Electric On-Road 9 02-06-2004 11:37 AM
