Old 10-05-2006, 06:30 AM   #1471
Pyramid's Avatar
Originally Posted by eduardo_garcia
The 720 cames with 6% of overdrive. it is a lot for me. I will change the pulley (main axe) to 21t. It may give the same overdrive of the 710 (about 1.5%)
this may helps: http://www.daltonshop.com/raceresult..._GearRatio.zip
Pyramid is offline   Reply With Quote
Old 10-05-2006, 06:42 AM   #1472
Originally Posted by Julius
How do you get 6% overdrive?
A 21t pulley on the 2 speed shaft is standard on the 720!
Were you using a 22t on the 2 speed? I can understand your 6% that way!
My 720 came with the following configuration:
front dff: 35t
center shaft middle: 19t
side puley (side belts): both with 22t
main axe center pulley: 24t
rear diff: 47t
Since both side pulleys are equal, we can jsut compare the relation between the front and the rear belts. Therefore, the front relation is 19/35 = 0.542 (each rotation on the main axe is 0.542 rotation on the front wheel) The rear relation is 24/47 = 0.510. Therefore, the difference is 6% (the front wheels are 6% faster than the rear) Ins't it correct?
If the car should came with a standard 21t, this is the thrird main fault on my kit. it's very sad, serpent always delivered top quality products.
eduardo_garcia is offline   Reply With Quote
Old 10-05-2006, 06:54 AM   #1473
front dff: 35t
rear diff: 47t
I don't have my owners manuel right in front of me.... Check yours and see what it says and what should be there... Make sure you're using the right pulleys... I would even count yours again to make sure you have the correct number on the front side and rear side... .02
RC_Alan
rc_alan is offline   Reply With Quote
Old 10-05-2006, 07:13 AM   #1474
asil's Avatar
Send a message via MSN to asil
front dff: 35t
rear diff: 47t
According to manual, front side pulley is 22T and rear side pulley is 21T...
asil is offline   Reply With Quote
Old 10-05-2006, 07:55 AM   #1475
dj apolaro's Avatar
You are correct, the rear side pulley is 21, they did this to match the over drive of the 710. It is not exact, but very close and was done to not make confusion for the people switching from the 710 to 720.
dj apolaro is offline   Reply With Quote
Old 10-05-2006, 08:05 AM   #1476
I've just check my manual. You are correct, it should be 21t. However, my kit came with 22T.
Old 10-05-2006, 08:47 AM   #1477
Pyramid's Avatar
it is worth counting the teeth itself because the plastic holder (before c clip) always say 22t and the factory kind of slice the wording off. Maybe in your case they did forget to slice off the wording but in fact the tooth is 21t?
Old 10-05-2006, 02:46 PM   #1478
1FastSerpent's Avatar
Ok ,, since the topic is at hand. Has anyone tried the 22 tooth rear side pulley. if so ,, how did it affect the car, and did it change your rear tire wear?
I've been wanting to try it.
1FastSerpent is offline   Reply With Quote
Old 10-05-2006, 11:31 PM   #1479
asil's Avatar
Originally Posted by deepfree_z
Hi,
I try 22t front side pulley to give some over drive to my 720. It worked very well and the belt tension is very good now.( with pro side belt) And you can use the old alu 22t pully too.
Here's the answer
Old 10-06-2006, 06:34 AM   #1480
Here's the answer
But the standard front pulley is 22t. 22t on the back will increase the overdrive to 6%
Old 10-06-2006, 07:00 AM   #1481
asil's Avatar
deepfree_z says he used 710 22T pulley on 720 for rear...
Old 10-09-2006, 06:16 AM   #1482
But the standard front pulley is 22t. 22t on the back will increase the overdrive to 6%.
Yes the ovedrive ratio will be 6% but you should consider the difference between front and rear tyres. That's why I say you should use 3mm split. With 3mm split the overdrive is 1%.
deepfree_z is offline   Reply With Quote
Old 10-11-2006, 03:39 PM   #1483
Trader Rating: 16 (100%+)
Quick 720 question....does 710's front and rear ball diff 802370 and 802380 fit Serpent 720...? On the 720 reference manual said they are the diff options, but I have ppl telling me it won't...please advise. Thanks a million.
Old 10-11-2006, 03:49 PM   #1484
Send a message via ICQ to _cyclops_
Front fits like normal.
For the rear, you need to get a new pulley, change that and it should fit!
_cyclops_ is offline   Reply With Quote
Old 10-13-2006, 01:01 PM   #1485
Derby Bros Racing's Avatar
Attached is what the reference guide calls for to have ball diffs. The stock gear diffs are 35T front and 47T rear. The ball diffs of the 710 are 35t front and 45T rear.
Cyclops is right, just change the rear to a 47T (part#808376) and it should be fine.
Derby Bros Racing is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
