Old 09-02-2006, 09:55 AM   #1321
Originally Posted by Roniel_R
Hey Sam:
Here is Scotty Gray setup from the sedan nats at crystal park,hope it helps..
Track (if not listed) : Crystal Park Raceway
Traction : Good
Track surface : Bumpy
Qualifying result : 20 laps 5:07
Qualifying position : 6th
Downstops : +1mm
Set-up ride height : 8m
Camber Left : -1.5 degree
Camber Right : -1.5 degree
Track-width : 199mm
Toe-in : toe out 0.5 degree
Caster setting (mm in front) : 4mm
Roll-center position upper arm (mm) : lower
Downstops : 6mm
Set-up ride height : 8mm
Camber Left : -3.0 degree
Camber Right : -3.0 degree
Toe-in : +2.5degree
Track-width : 200mm
Roll-center position upper : inner
Roll-center position lower : low
Springs : blue
Oil : 45W
Holes : 3
Cilinder type : alum.
Shock-tower position : 1st hole
Springs : blue
Oil : 45W
Holes : 3
Thickness : standard
Position : full hard
Thickness : 2.5mm
Position : 5mm
Position on lower arm : outside
Make : JACO
Hardness Left : 45shore
Hardness Right : 45shore
Diameter : 60mm
Make : JACO
Diameter : 61.5mm
Pinion 1st : 17T
Pinion 2nd : 23T
Gear 1st : 61T
Gear 2nd : 57T
Type : Locked Oneway
Type : Gear Diff
Diff. setting : 20 W oil
Body : Stratus 3.1
Engine : MEGA ZX12
Version : RACE
Head shims : 0.55mm
Glowplug : 7 cold
Fuel : Maxy Race Blend 30%
Here Is Scotty Gray Setup for Crystal Park (posted by Roniel R in the Kamikaze Thread
Paolo M is offline   Reply With Quote
Old 09-02-2006, 10:01 AM   #1322
Originally Posted by rangulo
Tosolini's Set up I put on the 720...Here is the setup he and Scotty Gray had. Paolo had a one-way setup that was different..
Tosolini
Front
front belt tight
Solid axle in front and I used dog bones that have been shortend to allow for the width to be less than 200mm.
1/2 deg toe out
2 deg camber
2mm shims outside steering link to lower and flatten link to reduce the bump steer
Swaybar 90deg
blue springs
45 Serpent Oil 3 hole
Shocks layed all the way down
2mm castor clips in front of arm
199mm width
middle roll center position
-2 droop measured on front upright
42 shore serpent jacos 57 qualifying 60 racing
7mm ride height measured with racing tires
Rear
rear belt med tight
3 toe in
blue springs
4 deg camber
2 hole 45 weight serpent oil
shocks layed down all the way
link in the lower position on the top of the upright
10k diff oil
roll center position 3 up from the bottom or middle high
+3 droop
swaybar on 1.5 mm in on the 2.5 mm bar
42 shore serpent jacos 58 qualifying 61 racing
8mm ride height measured with race tires
200mm wide
Standard bearings in car were really free with no grinding on the plastic to stop any sort of binding.. Car went together really good.
Proto Dodge stratus excellent for this setup and is what we used at the nats but Mazda 6 is easier to drive probably best for most drivers.
M11 with Spektrum Pro
If there is less traction run 40's or 38's. If car is traction rolling cut front tire width by 1mm at a time until it stops rolling.
If you have any questions please ask them here.
Here is Toso Setup for Crystal Park (Posted by Rafael Angulo on Kamikaze thread)
Old 09-02-2006, 10:37 AM   #1323
G4S'er's Avatar
Paolo,
Thanks for posting the setups on this thread for all to see. I have been asked several times for the same information and now being on a thread everyone sees should help a lot of racers!
I found some parts of these setup's interesting and very useful as I am sure others will as well.
Thanks !
Sam Felish
G4S'er is offline   Reply With Quote
Old 09-02-2006, 11:20 AM   #1324
Thanks Paolo... I know you've been busy getting ready for the Worlds...
RC_Alan
rc_alan is offline   Reply With Quote
Old 09-02-2006, 02:44 PM   #1325
bboytab's Avatar
Send a message via Yahoo to bboytab
Default 720 rvcr. batt
hi,
anybody knows where i can buy online a good receiver batt. for the 720.
thanks
bboytab is offline   Reply With Quote
Old 09-02-2006, 04:26 PM   #1326
ShermanSim's Avatar
Default serpent 720 parts and upgrade
Originally Posted by bboytab
hi,
thanks
Try,
www.kamikazercracing.com
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 09-02-2006, 09:00 PM   #1327
P-DUB's Avatar
Got to drive Maxy's 720 today and it's very impressive! Well done guys
PW
Larry Pryor
P-DUB is offline   Reply With Quote
Old 09-02-2006, 10:16 PM   #1328
ghoppa's Avatar
Trader Rating: 54 (98%+)
PW
Paul,
"do you plan on making a front bumper for the 720????" possibly a little wider to protect the front end a bit????
inquiring minds wanna know?????
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 09-03-2006, 12:48 AM   #1329
B4
B4's Avatar
Originally Posted by ghoppa
Paul,
I thought the bumper was very narrow but really hasn't proved an issue yet. Was has been an issue is the fragile nature on the bottom bumper mount, Julius says it's the same design as the 710 but now made with stronger material.
Maybe I have been unlucky to break a couple but what I did was get the Lola bumper plate and use a sander to shape it to 2mm back from the front of the foam. This gives much more material and the entire plate is thicker than the standard.
B4 is offline   Reply With Quote
Old 09-03-2006, 05:01 AM   #1330
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
hi,
thanks
you can get one here also...
http://www.promatchracing.com/proddetail.php?prod=7502
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-03-2006, 05:07 AM   #1331
Pyramid's Avatar
use the 710 bumper foam
Pyramid is offline   Reply With Quote
Old 09-03-2006, 10:59 AM   #1332
Send a message via ICQ to _cyclops_
Originally Posted by Sow&Steady
Yeah, and the pitrunner forgot to size it down to 26mm fronts and 30 mm rears.
Outch, painfull reminder
_cyclops_ is offline   Reply With Quote
Old 09-03-2006, 12:45 PM   #1333
markp27's Avatar
Send a message via ICQ to markp27
Default German Nationals
Just a quick message to let you guys know that Michael Salven won the German Nationals today. The weather was very mixed, with rain in the mid-phase. After it dried out Salven took the race in a very commanding manner in all the weather conditions.
Second place also went to a 720 in the hands of team driver Ralf Krause.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 09-03-2006, 01:33 PM   #1334
P-DUB's Avatar
Paul,
Yes...We have been waiting for Paolos to get us a bumper, but he has been very busy with World's prep
Larry Pryor
Old 09-03-2006, 01:43 PM   #1335
Paul,
U are rigth. Leaving tomorrow morning to Australia and still at the office trying to have everything ready.
Both bumper version, small and wide, are already on the mail
Paolo
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
