Serpent 720
#1171
Ok, for those interested, I've posted the 2006 EFRA 200mm European Championships race report online at 3hobby.net.
Even more important, Mark Green has shared his setup and it is now in the downloads section. To those who PM'ed me for it, thanks to Mark, you have it!
#1172
Originally Posted by Paolo M
REAR LOWER ARMS
The rear arm is now corrected. The inner inside hole has now more material (hard to see at first look) So, no need to find any special pivot ball.
If you had a problem with the arm and your are located in USA, please e-mail us at [email protected] and we will take care of you.
Thanks for supporting our products
Paolo Morganti
Serpent USA
Paolo Morganti
Serpent USA
#1173
new arms
Paolo,
I know you have say it is hard to see, but how can I know which arm is new and which old?
Thank you
Thank you
#1175
Originally Posted by sns820
I Just put the new Afl cap with the o-ring on my tank and it doesnt close all the way ,Has anyone else had this problem?
Maybe bind some elastic around it, to help the cap settle down......
#1176
Luke, ,,, James And Myself are going to make it down for a few more races. We have a new track opening this weekend here in Tampa. So we are gonna support them this weekend. it Also gives me a little more Data On this 720 with a smaller tight trac.
#1177
Watz up Mark getting practice for the state race i see
#1178
Originally Posted by Roedor
Paolo,
Thank you
Thank you
Outside it's the same. Inside there is a little bit more material inside the hole (if you measure the hole rigth in the border, will be the same diameter). Hard to see!!
Anyway, the first run are good enough to run. We won a National championship with those.
If you want to be on the safe side with the first version, you can put some teflon plumbers tape in the thread of the pivot ball and you are good to go. This way, you don't have to dispose the arms.
Hope this help
Paolo
#1179
Roniel,
I gotta get some practice in. YOu know, if you run sedan this yr we are gonna have some good racing. Plus I gotta get all the track time i Can Get , IF I don't do good at these 1/8 scale nationals I'm Gonna shd a tear I think. See you soon Bro.
#1180
UPDATE!
Serpent 720 1/10th On-Road screw kits are now in stock!
Serpent 720 1/10th On-Road 234-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Kits will begin shipping today, August 24th, 2006.
Thanks and best regards,
#1182
Did you happen to test the screws especially on the bottom of the chassis? The Serpent stock flanged screws fit perfectly. When I had a 710, I bought an aftermarket screw kit and the flange of the screws for the chassis didn't match and some had oversized heads which made it "stick out" of the bottom of the chassis. I ended up using the stock ones.
#1183
I have a few kits on the way down to Maxy Velazco so I'll know in a few days. But thank you for bringing that to my attention. I stand behind my products and want my customers to be 100% satisfied.
Personally, I run off-road and don't have the experience in on-road. But I gotta tell ya, I'm dying to order one of these on-road kits and slap my EB modded P5 with Kangaroo crank in it . I've had a ton of requests for on-road screw kits for months now, but I've been so busy I'm just now getting to it. I hope my on-road kits are as popular as my off-road kits.
#1184
Originally Posted by Team Kamikaze
Paolo,
Got my E-Mail?
Got my E-Mail?
Paolo
