Old 08-22-2006, 08:22 AM   #1156
How can I get my arms here in Brazil? I bought my 720 on USA.... I've also had problems with the shocks....
eduardo_garcia is offline   Reply With Quote
Old 08-22-2006, 11:06 AM   #1157
Eduardo,
If you have a US shipping address, we can help you. Please e-mail the info
Paolo M is offline   Reply With Quote
Old 08-22-2006, 01:27 PM   #1158
Originally Posted by 1FastSerpent
Luke what happened to you on Sunday?
I left early because something strange was going on in the rear of the drivetrain. It would feel really free when you turn it, and then lock up momentarily. It only happens when I put the rear belt on, people say maybe it's a bearing gone bad.
Luke W is offline   Reply With Quote
Old 08-22-2006, 02:08 PM   #1159
I'm guessing 1fastserpent is Mark Harrison...correct???
Old 08-22-2006, 03:01 PM   #1160
1FastSerpent's Avatar
yea, you got me.
I was looking forward to running with you guys. Your gonna love the 720,, if you haven't ran it yet.
1FastSerpent is offline   Reply With Quote
Old 08-23-2006, 01:25 AM   #1161
Originally Posted by Luke W
What he's saying is that when you have, let's say 3 degrees camber, and your tires are trued flat, the angle is only going to allow the very inner part of the tire to touch the ground. When you true your tires at an angle with the same camber, the wheel will still be angled at three degrees, but the tire will be flat on the ground.
Thanks Luke W
Acid
Acid is offline   Reply With Quote
Old 08-23-2006, 05:38 AM   #1162
Doug M's Avatar
Default New Steel Pinion
New steel pinion available for the 710 and 720.
http://www.mytsn.com/products/product.asp?prid=4344
Doug M is offline   Reply With Quote
Old 08-23-2006, 10:44 AM   #1163
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
awesome! doug did you get my email?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 08-23-2006, 10:54 AM   #1164
rcpanama's Avatar
Default Difference in Plug
Can some one explain the difference in using a Turbo C" glow plug very cold C8 TGC Novarossi and Turbo F" glow plug extra cold C8 TGF Novarossi and the difference between a short and long plug.
In Panamá we a have a very hummed and hot weather, 80 to 90% humidity and 28 to 34 degree.
RCPANAMA
rcpanama is offline   Reply With Quote
Old 08-23-2006, 11:28 AM   #1165
Doug M's Avatar
Yes I did, we are finalizing something and I think you will be very pleased when we are finished and I can reply.
Old 08-23-2006, 11:39 AM   #1166
Doug M's Avatar
RCPANAMA
Jump over to the Nito Engine Zone and do a search using "turbo plugs". You will find a thread headed "How to Select the Correct Turbo Plug? Please Help
Go to post #2 by afm, he has posted a simple explanation that should answer most questions.. There you will find an in depth explanation that you may want tp print out or save for future reference.
Old 08-23-2006, 02:41 PM   #1167
yea, you got me.
Do you think you might start coming to Pt. Charlotte more often? Traction is awesome now that Gary laid down new asphalt! I run 42's now!
Old 08-23-2006, 02:44 PM   #1168
Originally Posted by Paolo M
Eduardo,
You got a PM
Old 08-23-2006, 04:50 PM   #1169
afm
afm's Avatar
RCPANAMA
Turbo Glow Plugs where designed to give more performance to an engine, for the following reasons:
·It forms an uninterrupted combustion chamber.
·The advantage of better heat transfer or heat dissipation, and a leak proof seal, generated by the conical seat of the plug.
·The greater choice of thermal ranges, that allow for more precise tuning according to variations in weather conditions (temperature, humidity, height, barometric pressure, etc.).
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Mega Turbo 2315 6TF
Product Number: 2315
Wire Thickness: 6
Plug Type: T (Turbo)
Thermal Range: F (Fredda)(Cold)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head. The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they dissipate heat better and faster to the engine head. The number of threads is the same on both types of plugs.
·When the ambient temperature is high, we have to use a plug with thicker wire.
·Humidity determines if we use a Cold (F) thermal range, or Hot (C)(Calda) thermal range.
·With high humidity percentage we should use a Hot (C) thermal range plug.
·If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
The best instrument to determine which Turbo Plug to use, is those weather panels they sell for Yachts, that have Temp, Humidity and Barometric Pressure on them. Have it calibrated at your local weather station, and bingo, you’re ready like the Pros.
That is the key to success or failure tuning engines with Turbo Glow Plugs, because they are so sensitive to weather variations that is unbelievable.
Following is a selection chart for Novarossi Turbo Glow Plugs:
Type-Range-Temp.C°-Humidity%
C5TC-Hot/hot wire-0 to10- 70to100
C6TC-Hot/average wire-10to16- 70to100
C7TC-Hot/cold wire-16to25- 70to100
C8TC-Hot/ultra cold wire-25and up- 70to100
C5TF-Cold/hot wire-0to10- 40to70
C6TF-Cold/average wire-10to15- 40to70
C7TC-Cold/cold wire-16to25- 40to70
C8TF-Cold/ultra cold wire-25and up- 40to70
Hope this helps you
AFM
afm is offline   Reply With Quote
Old 08-23-2006, 05:44 PM   #1170
Sow&Steady's Avatar
Ok, for those interested, I've posted the 2006 EFRA 200mm European Championships race report online at [http://3hobby.net]3hobby.net[/url].
Even more important, Mark Green has shared his setup and it is now in the downloads section. To those who PM'ed me for it, thanks to Mark, you have it!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
