Serpent 720
Old 08-02-2006, 12:06 AM
  #886
Sow&Steady's Avatar
Originally Posted by J.Wright
"Yes you use the same tyres"
Thanks for the info, I just bought one and should have it in my hands in a couple of days. Also can I use the same Battries as in my V-one RRR WC? ........Boy you folks spell tires funny.
Jim
Jim, the batteries are different ... the 720 uses AAA size and arranged in a "L" shape below the tank. Go here and get them ... they've been made ready for the 710/720.
"Tyres"? Well ... how about we call "trunk" the "boot"? Or we spell socialize, "socialise"?
Sow&Steady is offline
Old 08-02-2006, 03:08 AM
  #887
B4
B4's Avatar
Originally Posted by Sow&Steady
Actually to be honest, I found the stock setting as per manual to be too soft (with the Mega engine in it). I think this is because the manual still asks you to set it like the 710. The internal ratio of the 710 is slightly different to the 720 and I found that when I first fired up the 720, it was engaging to 2nd almost immediately.
B4, like I said, this depends on your engine, tune etc. I had a fully race-tuned engine the first time I went out with the 720 and it was in 2nd right away. This could be your problem. I recommend screwing in say 1 to 1-1/2 turns and then try again revving up slowly. Fine tune on the track after you are sure you're getting 1st gear.
Agree.
I don't remember having any 2 speed setting problem when i had my 710. I have just come from the RRR back to the 720 and the RRR has a bigger ratio difference between 1st and 2nd so it's easier to feel the change.
B4 is offline
Old 08-02-2006, 03:11 AM
  #888
B4
B4's Avatar
Originally Posted by Luke W
I also had lots of problems with my 720 2 speed. I had to run it on the track and that's when I discovered it was shifting right away. It seemed like the shoes had to be broken in, because I ran the car a few laps while it was shifting early, and after that I tightened the screws about 2 turns (yes, it was that early! ), and then I could hear it in the air and it seemed to shift harder on the track. Before I had run it on the track, no matter which way I went with the screws, I couldn't hear it shift.
Luke W,
Thanks for the info it''s confirmed my thoughts, but
I didn't think I would need to go in that far.
B4 is offline
Old 08-02-2006, 03:35 AM
  #889
Sow&Steady's Avatar
I said for the same setting on a new 2-speed as the 710, in the 720 it appears to cause the 2-speed to shift earlier (depending on engine tune). I did not say that I had problems with the 710.
Old 08-02-2006, 03:44 AM
  #890
B4
B4's Avatar
I did not mean to imply that you did have a problem sorry if it came across that way.
B4 is offline
Old 08-02-2006, 04:48 AM
  #891
Doug M's Avatar
Default New Optional parts
The following new optional parts that will work with the Serpent 720 have arrived in the USA. Serpent dealers will be receiving these parts shortly.
RCC Shock Absorber Tool
http://www.mytsn.com/products/desc.asp?prid=4321
Tank Cap AFL + O-Ring Set
http://www.mytsn.com/products/desc.asp?prid=4336
Doug M is offline
Old 08-02-2006, 07:58 AM
  #892
J.Wright's Avatar
[QUOTE]
Thanks for the info mate; I have some 3k mAh NiMH AAA’s I can solder together in an "L" configuration. How’s that for spelling?
Jim
J.Wright is offline
Old 08-02-2006, 08:21 AM
  #893
Hey Doug, What's the advantage of the o-ring cap? I like the current design serpent has on their fuel tanks.
Luke W is offline
Old 08-02-2006, 10:45 AM
  #894
Sow&Steady's Avatar
No worries . ..
Old 08-02-2006, 10:52 AM
  #895
Sow&Steady's Avatar
[QUOTE=J.Wright]"
Jim
3k mAH???!!!
Great spelling though ...
Old 08-02-2006, 11:07 AM
  #896
Originally Posted by Qlone
At first sight, it seems the front lower wishbones would also fit.
The 720 versions look just the same, except they are made symmetrical, where the 710 ones only have attachment points at one side, making them usable only for L or R.
I put the 710 front wishbones on my 720 because because they seemed to be made of a slightly harder material. When i tried them back to back they definatly helped the car turn in better but i lost a bit of corner exit.
Just my opinion
Nick Simpson is offline
Old 08-02-2006, 11:13 AM
  #897
Doug M's Avatar
Default O-Ring Fuel Tank Seal
Previously the seal was created using foam but it has now been updated to use a rubber o-ring. The advantage of the orange o-ring is that it creates a better and more consistent seal over a much greater number of uses due to the fact that the o-ring won’t compress or deform over time.
Doug M is offline
Old 08-02-2006, 06:45 PM
  #898
rcpanama's Avatar
Default Finish 720
Ok I finish my 720, so I will be ready foe testing on Sunday, install a Novarossi R12-LL3 with the new Novarossi 2630 pipe.
Follow some pictures.
RCPANAMA
rcpanama is offline
Old 08-02-2006, 06:47 PM
  #899
rcpanama's Avatar
Default 720 no Body
Naked 720
RCPANAMA
rcpanama is offline
Old 08-02-2006, 06:48 PM
  #900
rcpanama's Avatar
Default Other side 720
Last picture
RCPANAMA
rcpanama is offline
