Old 07-28-2006, 08:15 PM   #826
Xyvern's Avatar
Originally Posted by 710baby
In the instruction manual it will ask you to unassemble the shock you will see a foam insert on the inside connected to the shaft disassemble the unit. I used a manifold spring tool to take off the foam. place 35 wt oil in a cap & place the foams & prime out the air you will see a lot of bubbles & let it sit for 5 minutes & reprime no more air reassemble them back & follow the bleeding system for your shocks. I used a pen cap to get them back on a little messy but if you do it right you shall get the shocks to rebound real good.
Still not clear to me how to remove the foam insert. I need to replace one of those because one of the foam inserts is longer compare to the rest of them and no matter what I do, I just can't tighten the shock.
Xyvern is offline   Reply With Quote
Old 07-28-2006, 09:39 PM   #827
ghoppa's Avatar
Trader Rating: 54 (98%+)
Originally Posted by eduardo_garcia
but only 750 mah?
charge them properly & you'll be fine for an "hour" long main....
call them if you "doubt" it, the Pros @ ProMatch or any major Battery Company will tell you the same...
High Quality NiMh cells which are rated @ 750maH are very different than those "so called" brands that have "unmarked" receiver packs rated @ 750, 850 or even 1000+maH.......
you can't compare apples to oranges......
everybody has their own preference on "everything".....that's what makes this hobby so fun....
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 07-28-2006, 11:40 PM   #828
GMartinez's Avatar
Trader Rating: 85 (100%+)
It's sorta like a tight rubber band you need to get under it & gently pull it off
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-29-2006, 03:38 AM   #829
B4
B4's Avatar
Default 2 Speed Setup
I set my 2 speed as per the instructions but I have not had the car on the track yet. Just holding the car and reving the engine I can't hear or feel the clutch engaging despite going in and out on the adjustment screws.
Whilst it will be not be the same setting for every track how many turns from from all the way down should I start with. I have adjusted the clutch gap screws as per the instructions.
I'm thinking once I have some load on the car I will be able to adjust it to my liking but i'm just after a good starting point.
B4 is offline   Reply With Quote
Old 07-29-2006, 08:37 AM   #830
dj apolaro's Avatar
Sometimes if it goes into second immediately you can not tell. When you rev it, at the same time look from the side. You will be able to see the shoes opening. When you do this make sure to rev it slowly. If you see the shoes hit the housing immediately then make it tighter. If you see the shoes do not move then they are too tight. This should help you at least see which way to go.
dj apolaro is offline   Reply With Quote
Old 07-30-2006, 08:09 PM   #831
I have teh same, but I can see that the shoes are opening, but I don't feel when it hits. I have an MF installed. A hear a change in sound but can't feel when it hits???
Edgar Millenium is offline   Reply With Quote
Old 07-30-2006, 08:32 PM   #832
B4
B4's Avatar
I can't even see the shoes opening despite changing the tension both ways. Maybe i'm just blind
Old 07-30-2006, 09:31 PM   #833
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
just bring your car to my house, or the shop, ill take a look at it for you carl. i dont see how one of your foam inserts is longer...
but ill take a look at it. swing by the shop tomorrow, well be open and waiting.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 07-30-2006, 10:02 PM   #834
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
guys, how do you install your e-clips with the middle shafts? i cant seem to install it since there is no gap or groove with the shafts and the e-clips just wont hold or maybe i'm just doing it the wrong way. another thing is one of my RCC shocks wont close or lock or tighten.i keep on turning it but the darn thing wont tighten
buboy28 is offline   Reply With Quote
Old 07-30-2006, 10:18 PM   #835
B4
B4's Avatar
The only e-clip on a shaft is on the main shaft to hold the first gear spur on. Other than that all the pulleys are mounted to their pully holder with an e-clip and than the pulley holder is slid over that shaft and locked in place with a grub screw.
With the shocks just re read your instructions and make sure the pre assembled parts are fitted correctly and they should go together better than any other shock on the market. Be sure to massage plenty of oil into the membranes before fitting together.
Old 07-30-2006, 11:00 PM   #836
buboy28's Avatar
the middle shaft have 2 e-clips one is near the 22T pulley and the other one is between the bearing and the 19T pulley, this 2 e-clips that i cant install i might have to re read the manual again, no problem with the main shaft already done it.
will follow your advise regarding the shocks, thank you very much
Old 07-30-2006, 11:27 PM   #837
rcracerdude's Avatar
Send a message via Yahoo to rcracerdude
i ran the car for the first time last friday night. Car handles very decent for stock set-up. Can't wait for next friday
The car handles much like my former mtx4, in stock form. However, the 720 is much easier to work on, in general. Tire wear is great! We're blessed with great design in the gearing department No more 2.5mm tire split 2-speed shifting is so smooth. I could hardly hear the shifting. Had to have my bro check the shifting point. Hate the dog bone up front though. Time to get front CVD's; rear not an issue.
I have to give serpent kudos with some new trick designs: the diff having ball bearing loaded on the outdrives, true easy access to front diff/one-way, new clutch system, shock design, rear sway bar design & more
I guess all I can say is, I'm very happy with switching to the snake
Ken Gutierrez
derbybrosracing.com
rcracerdude is offline   Reply With Quote
Old 07-30-2006, 11:32 PM   #838
Xyvern's Avatar
One of the shock definitely has a problem, it just wont tighten. I don't think it's the problem with the foam insert. I will stop by the store next week when I have time or I will see u at Rev. next Saturday for sure.
Old 07-30-2006, 11:40 PM   #839
B4
B4's Avatar
I just checked the manual again in case my memory was incorrect.
Step 2.12 The sections within the blue dashed line go together and then they attach to the shaft.
Step 3.2 is exactly the same.
The pulleys are attached to their holder by an E-Clip and then the holder goes over the shaft.
Old 07-30-2006, 11:51 PM   #840
i had that problem too. in my case, the shock cover was stripped. I noticed that when i had to open it to put oil - the threads are stripped. Whoever built one of my shocks may have stripped it. Check that.
Ken Gutierrez
derbybrosracing.com
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
