Old 07-27-2006, 01:50 PM   #811
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by Sow&Steady
Well, OK, never mind. I'll let you beat me again as long as you drive the 720 OK? That should make you feel better.
720? what 720? *cough* I think you're confusing me with a good friend of mine
markp27 is offline   Reply With Quote
Old 07-27-2006, 11:09 PM   #812
GMartinez's Avatar
Trader Rating: 85 (100%+)
Just got a good tip on the shocks before you start to build them there is a small foam insert that needs to be primed with the shock oil.
take a bottle cap & use the same oil & prime out the air then put the shock back together. This will help you in not having to rebuild them again since there is air trapped in the foam & even though the shock feels good in a couple of days they will have air in them
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-28-2006, 12:07 AM   #813
Julius's Avatar
Good tip. It's the way I do it and indeed saves you the one time rebuild.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 07-28-2006, 12:24 AM   #814
GMartinez's Avatar
These shocks are really good full rebound no play at all
Old 07-28-2006, 02:25 AM   #815
Sow&Steady's Avatar
I know you don't have one and that your friend is building one for the 3hobby.net build review BUT -
1- you can always borrow his car and
2- the fact that you're lurking in here tells me you have a 'George Clooney' weakness of keeping in touch with old flames and still love them.
(And before you ask ... no, you don't have George's money nor looks! )
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-28-2006, 02:27 AM   #816
Sow&Steady's Avatar
I followed the manual by massaging oil into the foams but your tip is better.
Old 07-28-2006, 08:01 AM   #817
markp27's Avatar
I know [....more blah, blah......]
Don't have to ask Bro, we are identical twins, I've seen your face and we are definately ugly!
Old 07-28-2006, 08:09 AM   #818
Send a message via MSN to ejcabal
Default Shocks explanation
Please explain a little further how it is that you do it.
ejcabal is offline   Reply With Quote
Old 07-28-2006, 08:26 AM   #819
ghoppa's Avatar
Trader Rating: 54 (98%+)
http://www.promatchracing.com/proddetail.php?prod=7502
"worth every penny"...
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 07-28-2006, 10:28 AM   #820
I'm new to the new Serpent shocks. So, when filling the shocks, how much oil is required? Do you fill it up to the top of the shock threads or below that and allow the rest to bleed out?
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 07-28-2006, 10:37 AM   #821
Sow&Steady's Avatar
Mum always said you were so full of ... err, cheeky comebacks.
Old 07-28-2006, 10:38 AM   #822
Sow&Steady's Avatar
I fill them to halfway up the internal threads and then allow them to bleed as I screw in the cap slowly.
Old 07-28-2006, 12:26 PM   #823
Originally Posted by ghoppa
but only 750 mah?
eduardo_garcia is offline   Reply With Quote
Old 07-28-2006, 05:09 PM   #824
Default 2 720 kits left
If your still looking for Serpent 720 kits call PNP Hobbies 321-723-7318 or email at [email protected].. We have 2 of them left and they sell for $425 each.
PNP HOBBIES is offline   Reply With Quote
Old 07-28-2006, 05:09 PM   #825
GMartinez's Avatar
In the instruction manual it will ask you to unassemble the shock you will see a foam insert on the inside connected to the shaft disassemble the unit. I used a manifold spring tool to take off the foam. place 35 wt oil in a cap & place the foams & prime out the air you will see a lot of bubbles & let it sit for 5 minutes & reprime no more air reassemble them back & follow the bleeding system for your shocks. I used a pen cap to get them back on a little messy but if you do it right you shall get the shocks to rebound real good.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
