Old 02-07-2011, 11:46 AM   #5056
Trader Rating: 8 (90%+)
Has anyone used the 733 rear end and the dls on the 720?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 03-26-2011, 05:53 AM   #5057
Default Help rookie racer with Serpent 720..!!!
Hi all,i`m getting a very nice deal on a new build Serpent 720 unruned with a new and not broken in Picco/JLR.12 red dot evo3 with sirio pipe and i think i`m buying it.
I`m new to rc cars and plan on racing it and i need some servos for it and need some suggestions.
I was thinking of the following servos for racing at my club:
Futaba-S9452`s
JR-Z9100S,Z9100T`s
Spektrum-S6030`s
Will all these servos fit on the chassis with no problems?,cause i have read the specs on the servos and some are bigger than others specially the JR`s
I hope you guys can help me out on choosing the best servos for steering and throttle for the Serpent720.
Also where is the best place for getting parts for my car?.
Thanks all.
FASTGIMS is offline   Reply With Quote
Old 03-26-2011, 09:23 AM   #5058
gfilos's Avatar
futaba 9452s are of very good performance and durable too..I have them 3 years now without any problem at all. Also they ll fit the 720, i had them on my 720..
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 03-27-2011, 07:09 AM   #5059
Gonzo RR's Avatar
you cant go wrong with Futaba servos.
I'm trying Savox servos on my 720 they have some very competitive prices
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 03-29-2011, 10:08 AM   #5060
Ok, I have been having a problem with my 720, shredding first gear. It started happening last year before i put it away for winter, I have completely rebuilt the car, and it is still doing it! When I have both first and second gear on the car, the first gear will mesh, then by turn them by hand, after acouple of revolutions, the first gear teeth no longer mesh, then by forcing the gears along (by this time they would already be stripped), they start to re-mesh again!
So, I have replaced the motor (figured bad bearings?), replaced the bearings inthe clutch, and in the transmission. I have replaced the pinions, and the spurs, and I pulled out the transmission shaft and it appears to be straight (i rolled it on a cast-iron table saw top).
The pinions are a 16T, and 21T, the spurs are 61, and 56T.
I was told that if the teeth added up for both first and second gear then the mesh should be okay. (77 for both).
I am at a complete loss now, The problem seems to only happen when I have both first and second gear on the car, which makes me think the gear sizes are wronge some how.
Any suggestions?
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-29-2011, 11:04 AM   #5061
nitrodude's Avatar
Chetck you bulkehead bearings too, and make sure the chassis isnt bent. Maybe your gears are for the 733? They look similar, but they're not. 2 years of running the 720 and I never had that problem, its strange. I would replace the shaft, it may look straight, but its probably bent. ALso, make sure the motor is not moving.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-29-2011, 12:47 PM   #5062
Whats different about them? Are they a different pitch? That would make sense of how they get out of sync. I know the pinions are 720, but I will have to see if I can find some older spur gears then. I was under the impression only the pinions changed. I am going to order a new transmission shaft just to be on the safe side.
Looks like I am pulling the car apart tonight again, I gotta get this figured out before the points season starts!
Shawn
Old 04-23-2011, 10:02 PM   #5063
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
ok guys i picked up gonzo rr's 720 and want to give nitro a shot i have raced electric tc for 9yrs do lookin for some setup help for my first outing with it.
so im askin what kind of ride height u guys run on a parking lot race track and whatabout droop also. im the track dirrector for our club so i have control over the flow of the track and attempt to keep it flowing mid/high speed infield with no 180s out side dementions r about 180 x 80. also the car has a mega zx12 modded motor and gonzo ran 16%nitro thru it but in our area everyone runs 20-30% nitro so what adjustments would i need to make to run those higher quanities of nitro.
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-24-2011, 08:05 PM   #5064
Gonzo RR's Avatar
Justin for ride height gererally you would run 6-7mm front 7-8mm rear depending on track conditions.
If you want to run higher nitro % 20% should be ok with out any adjustments to the engine. I would recomend doing a brake in process.
If you want to run higher % then you would have to add a .1mm shim under the cooling head for every 5% of nitro (if I remember well) somebody correct me if I'm wrong
I think 16% should be just fine I run 16% on my OS .21VG that's on my GT when guys at my track run 30% and keep burning plugs and having tunning problems on the same engine
Old 05-16-2011, 12:40 AM   #5065
Default RX lipo.
Hey all. Just got myself a second hand 720 to try out gas onroad. Unfortunately the nimh receiver packs that came with the car have all died so im in need of a lipo receiver pack or 2 for the car. Any help on where to get them from or if somebody has one I can purchase that would be appreciated.
Bumpy is offline   Reply With Quote
Old 05-16-2011, 04:04 AM   #5066
Pattojnr's Avatar
Trader Rating: 19 (100%+)
try to contact your NZ Dealer for this product.
http://www.xceedrc.com/product/105000
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-17-2011, 09:39 PM   #5067
Bundy_Bear's Avatar
Patto are you getting a bit slack in your old age!!! What about buying the AAA NMH cells and making the battery yourself
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-17-2011, 10:07 PM   #5068
Pattojnr's Avatar
Andrew
because if your using the HV servos, you dont need tyo run a reg anymore, so the lipo then has its advantages. your calling me slack ? you built the 733 yet ?
Serpent - Walter RC
Old 05-17-2011, 10:16 PM   #5069
Bundy_Bear's Avatar
Nah, not built anything been playing the PS3 instead. I can press restart and start again when it all goes up to shit!
MissMooRC Racing
Old 06-22-2011, 04:33 PM   #5070
i have my recently purchased 720 "08" for sale along with over $400 in parts plus all electronics and anything else i have related to nitro. our class died here this season
do a search for " serpent 720 rtr" for all the pics
i have well over $1500 invested
just askin $400
Justin & Matt Lyons
a800s sanwa m12s
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
