Serpent 720
#5041
serpent 720
thankyou so much guys, realli appreciate yr comments, i am using DJ setting at the moment, seems to be working, but i have yet to push the car reali hard. I realli love 720, if fact i think the 720 is even lighter than 733. jus wondering which is a faster car with same driver and same engine??? since 720 with LCG chassis will be realli light in weight...
#5042
I'll take some good pics of the 720 and post them here. I'm just glad to know I'm not the only one still running it.
#5043
The 720 was a good car and will be just fine whenever you decide to push it. If you need any help just ask.
DJ Apolaro
#5044
i love my 720..its just a bit*ch to work on.
#5045
serpent
Thanks DJ, for a track like this, is it better to have a softer spring behind?? I like to throttle to turn in.
#5046
DJ Apolaro
#5047
A track like what? I always like my 720 with a harder spring in the front and softer in the rear. usually a 2 step difference. Sometimes a 3 step. I mainly ran yellows in the rear and bounced back and forth between blue and purple fronts. Used a locked front end and 30,000 to 50,000 in the diff. For lower bite use lower rear diff oil, as low as 10,000 for really loose tracks.
DJ Apolaro
DJ Apolaro
#5048
serpent
thankyou DJ and the rest for yr info. i will try all the above setup on a smalll technical, high traction track here. i am now stuck, on decding to continue to hop up 720 or save the money and get the 733. any suggestions?? i like the fact tat 720 is much lighter expecially with the LCG chassis, is tat correct??
#5049
The chassis is where you want all the weight to be at. So your LCG is doing harm and good. Its good because everything is lower, but its bad because its light at the lowest point of your car. I always used the front brass brace and the brass battery brace to compensate for this chassis.
#5050
serpent
ok, yr advise would be to get the 733 rite?? as its a easy car to drive??? and handles better?? i am jus trying to convince myself to make a decision.
#5055
selling a brand new Serpent 720 09 edition......look
http://www.rctech.net/forum/r-c-item...9-edition.html
