Old 05-13-2009, 09:11 AM   #4906
Trader Rating: 34 (100%+)
DJ or anyone else,
How much camber do you cut into the tires (front and rear)?
Monti
Monti is offline   Reply With Quote
Old 05-13-2009, 09:35 AM   #4907
Team Kamikaze's Avatar
Originally Posted by Monti View Post
DJ or anyone else,
Monti
1 degree on the rear and 0 in the front.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-13-2009, 08:29 PM   #4908
quietstorm76's Avatar
Yeah what he said
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-14-2009, 01:05 PM   #4909
intimidator's Avatar
Dont know how to put a link to ebay,but i have two 720s on there for 350 for both.Just search serpent 720.One car is assembeled second car is not,there are tons of options,check it out.
intimidator is offline   Reply With Quote
Old 05-15-2009, 06:42 AM   #4910
s10dude's Avatar
nice deal....no money !
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-17-2009, 04:53 AM   #4911
and23's Avatar
How to improve steering in curve on my S720...
and23 is offline   Reply With Quote
Old 05-17-2009, 08:35 AM   #4912
fly_wheel's Avatar
Originally Posted by Julius View Post
I would advise you to make sure the connections between the cells are flexible. Especially between the top mounted cell and te one below it.
During crashes the top cell has a tendency to move (also slightly due vibration) and you will experience problems if the connection is rigid.
Before I switched to the Xceed lipo pack I used a long wire (about 5cm or 2 inches to connect the top cell to the rest of the pack and laid it in the recess between the cells.
make sure u use superglue to hold each cells before u solder... i use a thin piece of copper to cennect between each cells...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 05-17-2009, 08:36 AM   #4913
oze
Originally Posted by and23 View Post
How to improve steering on my S720...
Please specify what you want to achieve. It is hard to help on this question.
oze is offline   Reply With Quote
Old 05-17-2009, 02:16 PM   #4914
beta bob's Avatar
Trader Rating: 2 (75%+)
hey guys finally ran the car and its awesome but my front belt is a little to loose and i have the eccentric holders at neutral and i can't get them to the tight setting. Does anyone know an easy way to do this?
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 05-17-2009, 06:23 PM   #4915
Julius's Avatar
Once the top brackets are off, take the front belt of the diff/oneway pulley. Just pull the belt to the side and rotate the diff/oneway. Then lift up the diff/oneway and rotate the excenters and set the desired position. Make sure both sides are in the same hole (I put some white paint on the excenters so they are easily visible throught the holes in the bulkhead).
Then put the belt back on (again rotate the diff while pulling the belt back on). reinstall the top brackets and you're done.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 05-20-2009, 09:35 PM   #4916
Default Body Piant
Hi
does anyone know where I can get a custom paint job for my body? or someone that does this well?
jjrctech is offline   Reply With Quote
Old 05-20-2009, 09:44 PM   #4917
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jjrctech View Post
Hi
Is it for a serpent 720?
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 05-20-2009, 09:49 PM   #4918
yes for a serpent 1/10 car
Old 06-01-2009, 03:22 AM   #4919
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Default WA 2009 state tiltles
like to let you guys know, the 720 was on its game this weekend. after trading blows with Xray driver John Moyle (aka GRUB) the 720 TQed, set new lap record at 15.9 sec. first tourer ever in the 15 sec bracket. and came home with the win , after John had major problems with his car, the officials, and first corner carnage. Thanks to DJ for his help with pipe , header and clutch settings, was just a bullet everywhere, thanks, DJ
just a note as well, the 966 also set the new lap record, and first 8th scale int he 14's. TQ but had servo issues with 3 or 4 mins to go . was going to be a thrilling race till the car became so hard to steer, then servo then locked up. so a great weekend for myself , and Serpent, and novarossi engines.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-01-2009, 05:09 AM   #4920
Congratulations on your track record and the win. Way to represent the Serpent 720.
Primary Weapon: ?
Secondary Weapon: ?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
