Serpent 720
#4876
Hi to my friend out there!!!
ALG
#4882
Drive Calculator available for download from mytsn.com!
http://www.mytsn.com/products/downlds.asp?prid=4334
Screen shot of the program....
cheers
Frankie
#4883
hummmm...don't know ?
#4884
Hey Guys,
I have looked all over this entire thread and cant seem to find how to create a receiver battery pack for the 720, been given some drawings and some images but need a image of differant angles showing the entire setup and how the plugs are layed out.
Can you 720 Guru's help a new serpent lover!
Cheers
Frankie - Cant wait for the snake to land in my hands SOON!
Cheers
#4885
use 5 pieces of AAA batteries. depends on ur receiver, but usually 3 pins, so the 1st pin is (-) black and 2nd pin is (+) red, 3rd pin is signal which is useless for battery pack. build as in drawing.
* Note: (+) Red. Positive wire is longer than (-) wire. use glue to hold each cell together when soldering.
good luck..!
good luck..!
#4886
good luck..!
good luck..!
Regards
Frankie
#4887
During crashes the top cell has a tendency to move (also slightly due vibration) and you will experience problems if the connection is rigid.
Before I switched to the Xceed lipo pack I used a long wire (about 5cm or 2 inches to connect the top cell to the rest of the pack and laid it in the recess between the cells.
#4888
good luck..!
good luck..!
#4889
