Old 04-25-2009, 12:30 AM   #4861
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Team Kamikaze View Post
looks Good Sam , but gearhead was trying to use the tool he has. just trying to help him use what he has to get it sorted. but yeah , this tool would work much better.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-25-2009, 12:39 AM   #4862
Team Kamikaze's Avatar
The problem with the tool he is trying to use, is that if the trust bearing seats lower than the outer rim of the gear itself, then it won't work, but a caliper can be used, but will more likely give you false readings.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-25-2009, 01:13 AM   #4863
Pattojnr's Avatar
agreed, thats why i use digital calipers. but the tool you linked to would be more precise for sure.
Serpent - Walter RC
Old 04-25-2009, 07:43 AM   #4864
DS Motorsport's Avatar
When setting the gap with a wc clutch set you leave the first gear pinion off the clutchbell, this way the tool slides right in. When you're done setting the gap, put first gear on and set the endplay.
Btw i allways let one small bearing sit in the bell, so the bell is guided properly over the crankshaft, it doesn't make a difference in measurement.
No need for such a expensive tool. Endplay i allways set without measuring, just get the least amount of gap without the bell binding with the trustbearing.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-25-2009, 09:05 AM   #4865
Sam's right on the relationship between the thrust bearing and the gear's outer rim. Iím lucky in that for whatever reason on my 720 the top of the thrust bearing is slightly above the gearís outer rim and I'm able to measure the gap with a set of feeler gauges which you can find almost anywhere for a few bucks (only wish that they had a nice slot cut in them so I could slide them all the way in). Mine was one of the original 720s, did Serpent make a design change in their gears or thrust bearings along the way that changed this relationship?
Itís funny that Hudy makes a nice expensive tool that among other things is able to measure the gap using the above ďfeeler gaugeĒ method. It would work on my 720 but it wonít work on my NT1 because the top of the thrust bearing sits below the gear rim on this car. Unfortunately there is not enough total clearance for me to put a shim under the thrust bearing to raise it up slightly or possibly use another slightly thicker thrust bearing and still achieve my desired clutch gap. I guess I could look into the possibility of modifying the collet to allow the entire clutch assembly to move back slightly thereby creating a slightly wider gap.
The gauge that Sam recommends is nice but is a little steep for my wallet. I wish someone would make a set of reasonably priced attachments that can be used on any dial indicator gauge. There could be an attachment for this use as well as attachments that could be screwed into the glow plug hole to measure piston position and probably a number of other useful attachments that I canít think of off the top of my head. I have a nice digital dial indicator that I picked up from Harbor Freight for a very good price that is more than adequate for the job. Iíve thought about having some attachments made for myself, but never gotten around to doing it.
I'll have to try DS's method, but at least on the 720 I thought the thrust bearing actually was supported by a rim inside the first gear pinion. I could be wrong or maybe the WC clutch is different than the stock clutch.
calvin is offline   Reply With Quote
Old 04-25-2009, 10:03 AM   #4866
Pattojnr's Avatar
the WC clutch bell and pinions are different. the LC clutch setup , you can not remove the 1st pinion like DS said, as it retains the bearing and the thrust bearing. this method will only work for the WC, but removing the pinion all the time is a hassle to check your settings all the time. a digital vernier is the cheapest method but not as accurate as the Tool from Sam.
Serpent - Walter RC
Old 04-25-2009, 10:50 AM   #4867
gearhead_22's Avatar
Send a message via AIM to gearhead_22
thanks to all for the help. The tool that sam has is a bit high for my buget. and thanks DS I"ll try it your way.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 04-25-2009, 10:55 AM   #4868
The tool is just a suggestion, but as Calvin mentioned, you can use a feeler gauge to measure endplay.
Old 04-25-2009, 10:56 AM   #4869
yes the thrust bearing is supported buy a rim but in the manual it showes to put a shim under the thrust bearing.
Juwan Hunter
Old 04-25-2009, 10:58 AM   #4870
I ended up using a digital caliper.
Juwan Hunter
Old 04-25-2009, 11:09 AM   #4871
captian's Avatar
thats what i use
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-25-2009, 03:54 PM   #4872
I used to use a digital caliper too, but I swear that I could take ten different measurements and get ten different answers. After I figured out I could use a feeler gauge on the LC clutch (don't know about the WC), I never looked back. I'll have to check tomorrow, but I may have to apologize to Hudy as I guess it's possible to use their tool (or a set of feeler gauges) on the NT1 by making the measurements without the 1st gear pinion installed as DS suggested above for the 720 WC clutch - learn something new every day.
Old 04-25-2009, 04:31 PM   #4873
beta bob's Avatar
Trader Rating: 2 (75%+)
Thumbs up
Just finished my car and man this thing is sweet looking now i just have to wait for my engine/pipe and servos to come in and then i will have a car to race!
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 04-25-2009, 07:49 PM   #4874
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Congrats on the car Bob you will enjoy the car.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-26-2009, 05:33 AM   #4875
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
i have a thingo for photos so it would be sweet to showcase the new ride.....
"so am waiting for my kit to arrive" BAD!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
