Old 04-23-2009, 04:40 AM   #4846
beta bob's Avatar
Trader Rating: 2 (75%+)
Originally Posted by ~McSmooth~ View Post
I heard Serpent is gonna do away with the number system and go with "fast and exciting" names for their cars.
Word is, this new car will be called the "ButterHawk XLS"
I hope your joking that is not even a good name
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 04-23-2009, 05:24 AM   #4847
Pattojnr's Avatar
Trader Rating: 19 (100%+)
cant you tell by his AVATAR, hes deadly serious ................
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-23-2009, 05:29 AM   #4848
Sow&Steady's Avatar
How right you are
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-23-2009, 07:07 AM   #4849
s10dude's Avatar
what would you expect from a name like McSmooth ?....
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 04-23-2009, 07:23 AM   #4850
Pattojnr's Avatar
id expect it to be thick , a bit cool, and left out in the open for a while, a bit runny. Mc Smoothie whats ya Flovour ?
Serpent - Walter RC
Old 04-24-2009, 07:15 AM   #4851
s10dude's Avatar
Old 04-24-2009, 08:09 PM   #4852
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Default wc gears
I am puting the centax-3 clutch-set wc #803230 on my 720. I can't get my clutch gap tool in.I read the manual, also there nothing to stop the smaller bearing from sliding up. help please got to get ready for 301 sunday.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 04-24-2009, 08:56 PM   #4853
Pattojnr's Avatar
if you cant get the tool in to measure your gap, do you have the pinions on the right way ? the second pinion has a cut out so that the 1st pinion sits inside the second pinion just a little bit. if its around the wrong way, then the 1st pinion sits out further, then you may have problems getting your tool in to set your gap. as for the bearings, not sure what you mean about them from sliding up ?
Serpent - Walter RC
Old 04-24-2009, 09:32 PM   #4854
I have the gears on right that is one thing i checked. What I mean about the bearings is that the smaller ones can slide right through the clutch bell.
Juwan Hunter
Old 04-24-2009, 09:53 PM   #4855
Pattojnr's Avatar
once the clutch is together and shimmed right, the bearings wont be going anywhere. i dont have any cars here or my stuff. so i cant see where you are going wrong with the shimming. if you cant get the tool in, then the 1st pinion is obstructing the tool from working ?
Serpent - Walter RC
Old 04-24-2009, 09:57 PM   #4856
spurgear's Avatar
Send a message via MSN to spurgear
Did u use the big bearing then two smaller bearings with no spacers or shims in between?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 04-24-2009, 10:20 PM   #4857
I put it together just like the manuel shows. from what I can tell the gear is higher than the thrust bearing and if i put a shim that comes with the set under the thrust bearing it falls through because it showes to set up clutch gap without the clutchbell bearings.
Juwan Hunter
Old 04-24-2009, 11:16 PM   #4858
Pattojnr's Avatar
yeah i can see whats happening here. maybe try using all the bearings in the clutch with no shims. may stop the thrust bearing falling in side with no bearings fitted. if the bell bottoms out on the shoe, and moves in and out a bit, then there is no harm using the bearings to use your setting tool.
Serpent - Walter RC
Old 04-24-2009, 11:39 PM   #4859
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The new black Xceed rims are sick.
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 04-24-2009, 11:50 PM   #4860
Team Kamikaze's Avatar
How about using this tool? http://kamikazetoysandhobbies.com/pr...php?prod=TTCT1
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
