Old 04-07-2009, 03:53 PM   #4726
and23's Avatar
Originally Posted by Killa G View Post
Post your setup and we could probably steer you in the right direction.
Are you struggling with initial steeringm mid corner exit etc?
Gael
This my Setup:
I have used also the Steering Blocks Evo2 720 - 1 (#803212)
and23 is offline   Reply With Quote
Old 04-07-2009, 04:30 PM   #4727
quietstorm76's Avatar
Originally Posted by and23 View Post
This my Setup:
where is the car not steering? Off power or on power?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-07-2009, 06:07 PM   #4728
Gael L's Avatar
This my Setup:
depending on the size and flow of the track I would start with two things. FIrst go with 38 fronts and 40 rears. Secondly a diff tends to be more consistent but you should try the spool up front. I would also go with 40wt shock oil with 3 hole pistons front and rear. this setup should get you close to what you are looking for.
Hope this helps
Gael
Gael L is offline   Reply With Quote
Old 04-07-2009, 08:35 PM   #4729
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Since ur using the 1 degree blocks u can also try switching the left one and putting it on the right side and vise versa.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-08-2009, 02:05 AM   #4730
and23's Avatar
Off power
Old 04-08-2009, 03:39 AM   #4731
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Off power
i dont use a front sway bar. i use a spool, 45w oil, 2 hole piston front, 3 hole rear, upper hole on the rear hub, and the use of the brass insert. i use new purple front spring, and red rear. my car does not push, and certainly not lacking steering. i also use 40 fronts and 37 rears. this is low-med traction track.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-08-2009, 08:58 AM   #4732
spurgear's Avatar
Send a message via MSN to spurgear
Would he have this problem if he had the longer Servo lever front installed? I have this installed ever since i built my car. So im wondering if to take it off. Which means i would get more ackerman. Would it make the car turn better?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 04-08-2009, 11:30 AM   #4733
When you use a front spool you will always have some off power push that's the nature of a spool you have to either give more throtle or use the brake to tighten up your line.
Old 04-09-2009, 01:22 AM   #4734
and23's Avatar
Thank you very much... now I will try the standard setup e after I will say you...
Old 04-09-2009, 05:12 PM   #4735
Rcchamp720's Avatar
Send a message via AIM to Rcchamp720 Send a message via Yahoo to Rcchamp720
ran my car yesterday and the back end was lose i was running red springs all around any suggestions
Rcchamp720 is offline   Reply With Quote
Old 04-09-2009, 05:15 PM   #4736
Gael L's Avatar
I am going to the track this Sunday. If you want you can meet me there and we can get the car sorted out. Traction was bit low last week so we will have to make a few changes from the stock setup. Let me know.
Later
Gael
Old 04-09-2009, 06:40 PM   #4737
Rcchamp720's Avatar
no problem i was actually planning on going out there hopefully regaurdless on sunday ull c me im goin to b running my orang body and my freind i drive with runs a white body on his x ray
Old 04-09-2009, 06:45 PM   #4738
LOW ET's Avatar
Trader Rating: 97 (100%+)
has there been any more talk of the new serpent touring car?
LOW ET is offline   Reply With Quote
Old 04-09-2009, 07:03 PM   #4739
intimidator's Avatar
Anyone use the lemans bumper?Im gonna make a bigger foam bumper to use with the lemans bumper.The kit one sucks.Is the the lemans one better than the kit one???
intimidator is offline   Reply With Quote
Old 04-09-2009, 07:26 PM   #4740
Has anyone ever had the pins in the dog bones slide out? I found this on the rear of my car and it was binding like hell. Is there a fix or just but some new ones? They hardly show any wear on them and the drive cups are not notched.
Primary Weapon: ?
Secondary Weapon: ?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
