Old 03-29-2009, 08:15 PM   #4681
Rcchamp720's Avatar
Send a message via AIM to Rcchamp720 Send a message via Yahoo to Rcchamp720
hey dan yea i checked your pm its not a problem at at
Rcchamp720 is offline   Reply With Quote
Old 03-29-2009, 09:06 PM   #4682
Rcchamp720's Avatar
Default i neeeedd a gas tank
please tell me that someone on here has a used 720 gas tank for sale i need one asap if so please pm me a price and let me kno maybe we can trade parts
Old 03-29-2009, 09:21 PM   #4683
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I believe ashfordhobby has it did u check yet.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-30-2009, 06:10 AM   #4684
dj apolaro's Avatar
Originally Posted by etgdpu View Post
Thank you guys for your feedback.
DJ, could you please comment on the:
1) do you consider a must for this setup the brass battery tray and the 30grams in the bumper? if yes, why?
2) tire size, do you intend to enter the 30 mins final with 60.5/59? what is the min acceptable diameter and difference rear/front at the end?
3) is the DR 75% in the acceptable range with this setup?
4) does the front solid cause premature wear to certain parts like front cvds or anything else?
//BR
Dimitris
1. In low bite the brass battery tray and weight in the front is not a big teal. 2. Tire size is hard to say. It all depands on tire wear. I run qualifiers with a 1.5 split and for finals I work backwards. (Lets say I can run down to 56 rears, then I add all the tire wear I am going to get to that number. The I add 1mm to that number to be safe.)
3. I would use 90-100% in your case.
4. the front solid does wear certain items more; cvd/bones, outdrives, etc, however not that much to worry about. Just keep everything oiled and greased.
Hope this helps,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 03-30-2009, 06:30 AM   #4685
etgdpu's Avatar
Hello again,
DJ just 2 more questions:
1) How many degrees the car should steer on the setup system with DR 100%? My car steers 28 degrees.
2) so you consider acceptable to end a race with 56/55? My continuous questions about this same thing is because I try to understand where is the sweet spot of the tire. Between 61 and 56 or between 64 and 59, let's say.
Thanks once more
Dimitris
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 03-30-2009, 06:36 AM   #4686
dj apolaro's Avatar
Hello again,
Thanks once more
Dimitris
1. I have not ever done it that way, sorry. I just eye ball it.
2. It is different for every track. The more bumps the larger tire is better. The flatter the track the smaller tire is better.
DJ Apolaro
Old 03-30-2009, 07:57 AM   #4687
rpoage's Avatar
The current tank for the 720 is SER 803216
Ashford Hobby SER 803216
rpoage is offline   Reply With Quote
Old 03-30-2009, 10:56 AM   #4688
Rcchamp720's Avatar
how much is shipping for the tank from your site
Old 03-30-2009, 11:02 AM   #4689
Its like 3-4 bucks order it today you will have it wednesday
Old 03-30-2009, 11:48 AM   #4690
Rcchamp720's Avatar
thanks dan
Old 03-31-2009, 07:08 PM   #4691
endy0430's Avatar
Trader Rating: 25 (96%+)
Default Serpent Camber gauge (#1460)
looking for this does anybody have it for sale?
endy0430 is offline   Reply With Quote
Old 03-31-2009, 07:53 PM   #4692
Hey Endy if you have the funds you should get the hudy set-up fixtures I believe ashfordhobby.com has them for 145. This will be more accurate and you will be able to do toe as well as camber.
Old 03-31-2009, 08:26 PM   #4693
Rcchamp720's Avatar
would u be able to order it from serpentamerica
Old 03-31-2009, 09:29 PM   #4694
Camber guage out of stock at serpentamerica you could call them to see if they order it.
Old 03-31-2009, 09:33 PM   #4695
Hello Guys:
The Camber Gauge #1460 has been discontinued from Serpent, we are wating to verify if Xceed will have it.
Edgar Millenium is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
