Old 03-27-2009, 10:44 AM   #4651
Derby Bros Racing's Avatar
Originally Posted by rc4fun View Post
Thanks, do you have the part number' i will give it a shot' let see if wont change the handling'
Originally Posted by Team Kamikaze View Post
Jo. I have the Lola bumper, let me know if you want to include 1 with your current order.
Just a reminder that the lola lower bumper is not a drop-in-perfect part for the 720. You will need to be a little creative to retrofit the 720s upper and foam bumper.
Once you get it done though, you can forget about the bumper and it will save you a whole lot on parts for frontal crashes.
Derby Bros Racing is offline   Reply With Quote
Old 03-27-2009, 12:13 PM   #4652
Team Kamikaze's Avatar
The 803166 is the correct part number for the 720 LM type bumper, this bumper is made for the 720, unlike the 802209 which is an original part for the 710, so the fit shouldn't be a problem.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-27-2009, 12:19 PM   #4653
endy0430's Avatar
Trader Rating: 25 (96%+)
do you guys have the upgrade shocks for the serpent 720 09 edition send me a link if you do....
endy0430 is offline   Reply With Quote
Old 03-27-2009, 12:26 PM   #4654
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I think the upgrade kits aren't available yet but very soon like in a few weeks
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-27-2009, 12:47 PM   #4655
That's right (thanks for the update it's only been about a year since the last time I raced onroad ). Although you will still have to be a little creative trimming the plastic to be right on or a hair off the sedan body. That way it follows the contour of the actual lexan.
Old 03-28-2009, 08:48 AM   #4656
Rcchamp720's Avatar
Send a message via AIM to Rcchamp720 Send a message via Yahoo to Rcchamp720
Default serpent 720
does anyone have an gas tank for sale for a 720
Rcchamp720 is offline   Reply With Quote
Old 03-28-2009, 09:12 AM   #4657
rc4fun's Avatar
im selling my 720 kit without the front lower bumper plate, if you want i will sell it cheap bro', im switching kit, let me know
301raceway' onroad track "Eastcoast proud"
Blue Diamond on-road track
Hobbyworks Fairfax________Brooklyn hobbies
rc4fun is offline   Reply With Quote
Old 03-28-2009, 09:13 AM   #4658
cho~ke's Avatar
http://www.kamikazercracing.com/home.htm call 714-997-8697 ask for sam
R&D = rebuild & destroy
Jimmy Cho
cho~ke is offline   Reply With Quote
Old 03-28-2009, 09:15 AM   #4659
here: http://kamikazetoysandhobbies.com/pr...hp?prod=803216
Old 03-28-2009, 09:50 AM   #4660
Rcchamp720's Avatar
for how much and r u willin to trade it
Old 03-28-2009, 09:54 AM   #4661
Winner's Circle's Avatar
I have your fuel tank!
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 03-28-2009, 04:21 PM   #4662
etgdpu's Avatar
Hello all,
I set my 720'09 with the DJ's starting setup and I visited the local track for some practice. The grip was extremely low, because the track was very dusty. However, the car was consistent and predictable. I suffered from on power oversteer, which could be easily controlled if you compromised with a little lower lap times.
Could I have you feedback/answers to the following:
I did not install the extra 30grams in the front bumper and I used the plastic battery holder instead of the brass one mentioned by DJ in the setup. Do you consider those as big changes and how they will affect the car handling?
The proposed tire diameters 60.5/59 are intended for a 30min final? What is the lower limit for the tires diameter at the end of the final and what is the lower limit for their difference rear/front?
I used a Picco EVO3 engine and I had my clutch with the default fly weights, 31mm fly wheel, yellow shoe, 0.6mm gap, 0.1 end play and 1.5 spring preload. When the grip is there I use 0.7 gap and 1.6-1.7 spring preload. I don't have a complain with this set up but would you recommend something different?
Hypothetically, if I had to race with this low grip condition and I had to improve the on power oversteer on the corner exit, what should be my first change?
I had my dual rate set to 75%. Is it in the expected range for this setup?
Does the front solid axle use cause any king of premature wear on certain parts like front cvds or belts or anything else?
Thanks in advance
Dimitris
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 03-28-2009, 05:19 PM   #4663
You could try the same setup with a front diff with 100k wt oil or higher. Also what springs are you using front and rear. Those tire sizes could be qualifing size.
Old 03-28-2009, 06:48 PM   #4664
Rcchamp720's Avatar
Default 720
is it true that you are supposed to run softer springs in the winter season
Old 03-28-2009, 06:55 PM   #4665
breez1090's Avatar
dan that paintjob looks nice
Dwayne Island breeze II
Xray NT1 Xray T3
360 2.0
breez1090 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
