Old 03-02-2009, 03:09 PM   #4546
M7H
M7H's Avatar
Originally Posted by DS Motorsport View Post
The original centax 3 uses 5x10x3, that's why i guess they re-used those bearings. Below is the serpent number for the item.
1315 Kogellagers 5x10x3 (2)
Yep, but actually this is 5x10x4... 3 is wrong....
Serpent
M7H is offline   Reply With Quote
Old 03-02-2009, 03:17 PM   #4547
Pattojnr's Avatar
Trader Rating: 19 (100%+)
that part number is 5x10x4. i just finished building my new tourer and my reference book says 1315, 5x10x4, i can say for sure they are that size. but with WC you only need one inside, and the 2 smaller bearings outer.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-02-2009, 05:31 PM   #4548
endy0430's Avatar
Trader Rating: 25 (96%+)
Default doesnt fit right
hey guys I ran into a problem I can't figure out I'm on page 16 of the manual step 3.9 and the problem is the right side (if your looking from the back of the car) fits like it's supposed to but the left does not...does any body have an idea why?
I posted some pics
the first two are the right side and the last one is the one one that fits correct the left side any help will be appreciate...thanks
Serpent 720-picture-003.jpg   Serpent 720-picture-004.jpg   Serpent 720-picture-005.jpg
endy0430 is offline   Reply With Quote
Old 03-02-2009, 05:49 PM   #4549
nitrodude's Avatar
Make sure the ear on the eccenter is matching up with the notch on the bulkhead.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-02-2009, 05:50 PM   #4550
s10dude's Avatar
sometimes its hard to get the rear bracket to fit into the correct spot. make sure everythings loose so it will slip under and into place..good luck
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 03-02-2009, 06:34 PM   #4551
Gael L's Avatar
From the picture it looks like you may not have pivot inserts equal front to rear. Double check that. Also back off the droop screws a bit more. They look fine but that can cause this problem. Hope this helps.
Later
Gael
Gael L is offline   Reply With Quote
Old 03-02-2009, 06:45 PM   #4552
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Sometimes u have to just give it a little push but like was mentioned be sure the eccenters are both facing the same way
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-02-2009, 08:09 PM   #4553
endy0430's Avatar
Default thank you guys
I got it guys thanks for all your responses....had me stuck for awhile on that step.....
Old 03-04-2009, 08:49 AM   #4554
DS Motorsport's Avatar
Thanks, got the bearings now. This weekend i hope to find out what a serpent clutch does in a NT1
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-04-2009, 10:03 AM   #4555
M7H
M7H's Avatar
Maybe it will convince you of building a complete 720 around the clutch....
Serpent
Old 03-04-2009, 10:18 AM   #4556
I already had two 720's before i switched to xray, since the beginning i was disappointed with the quality and fit of the 720. Then when i saw the superior quality of the xray and had a test drive with it i was completely sold.
But i'm really interested in the new 722, with the aluminium bulkheads and such, because i really like the quality of my S400.
And Serpent still has that special feeling because it's our national brand.
P1-RC.com
Old 03-04-2009, 11:21 AM   #4557
Serpent has improved a lot since the first 720. The latest products have better fit and a lot stronger. The new line is going to be even better. Who knows, maybe we will set a new std in quality! We are working on it!!!!
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 03-04-2009, 11:24 AM   #4558
Originally Posted by Derby Bros Racing View Post
Way to go DJ and Paolo!!!
Congratulations guys!!
Old 03-05-2009, 02:38 PM   #4559
endy0430's Avatar
Default finally
well guys here she is my 09 ...no engine or electronics as of yet that's to come next......
Old 03-05-2009, 04:52 PM   #4560
Congrats now turn the rear body post the other way. And u may want to put 100,00 wt diff oil up front. Which steering blocks did u use the 0degree or 1 degree. Good luck where will u be running it.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
