Serpent 720
#4490
Thanks for your hard work and dedication. Wish you many more victories!
#4491
So, just to give some more info.
This are proto parts that were tested by Salven. Another driver had a set too, with the purpose of test the durability of the parts under extreme abuse.
DJ ran a complete stock car and i ran some parts from other parts in the rear to test and compare. We are working towards the 7XX, and no, i can't say no more..... but uis gonna be AWESOME!!
#4492
#4493
Thanks Paolo,
I am all warm and fuzzy inside. hahahahaha
DJ Apolaro
DJ Apolaro
#4495
Hey guys that first picture is my car 720 09 with twister tires the car was perfect and fast just the driver was not perfect.
#4496
Hello all ,First of all congratulation to all serpent drivers for victory on Winternats keep gooing the good job
Since 2 months i have purchase a serpent 720 with many option parts as lgc monoblock engine mount 3mm lgc chassis cvd front/rear centax 3 with WC gear pinnion etc
I participate to a local race season in my country and i would like somebody send me a basic setup to begin race easily, my motor engine is Mega mf12 masmo with 2602 pipe ,also the track is technical with small straight and closed turns
Thanks in advance
Thanks in advance
#4497
Thanks in advance
Thanks in advance
#4498
This is easy check this web site www.serpent.com/racing/setups/ with the best serpent driver setup so remember your driving still maybe different so try them out and good luck.
#4499
Clutch setup for Mega by Picco
Hello all,
Last year I was using the MF engine and with the clutch setup by Paolo I was very satisfied. Here it is.
Std flyweigths pivoting
yellow shoe
0.8mm gap
0.2 mm end play
hard grey spring 1.8 mm (909518) preload to 1.5mm or black hard spring 1.8mm (909520) preload 1.0mm
Now I am thinking to get a Mega DSII+ and I wonder which is the recommended setup for this engine.
Any recommendations for pipes for this engine?
yellow shoe
0.8mm gap
0.2 mm end play
#4500
DSII pipe suggestion
Hello all,
yellow shoe
0.8mm gap
0.2 mm end play
yellow shoe
0.8mm gap
0.2 mm end play
