Old 10-28-2008, 01:58 PM   #4201
Team Kamikaze's Avatar
Originally Posted by rangulo View Post
Hey DJ: Does that stand for Danger Joe
Wassup: Can I run a car with a little grease in the clutch and a small gap? Also my hinge pin is really tight and needs to be loose. What can I do?
Rafael,
You should spit on the hinge pin so it will go in easier, by the way are you installing the correct hinge pin? you know you can't install a "MAN'S" hinge pin in your Kkkar.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-28-2008, 02:16 PM   #4202
dj apolaro's Avatar
HAHAHAHA
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-28-2008, 02:20 PM   #4203
dj apolaro's Avatar
Originally Posted by gfilos View Post
Hello Dj Apolaro,
Went today for practice at the track today, using the setup changes you proposed:
- Changed front droop from 0 to -1
- Front roll center pins in the middle
- On hole upward on the front shocks
- Front ride hight 4mm
- Rear droop from 6mm to 5
- Rear Diff oil to 20.000cst
- Two holes upward on the rear shocks
- Rear ride hight 5mm
Using 37 shore rear and 35 shore front cut to 62.5 mm front and 64 mm rear.
The oversteer problem was dissapeared.. The rear traction was very good. However,
the car suffered from heavy understeer at corner entry and mid-corner..
I disconnected the front anti-roll bar and things went better. Then i switched from blue
front springs to red (old) springs which are softer and things went even better.
Very stable car, maybe just a bit off-throttle understeer at corner entry.
Tomorrow ill try increasing the caster a bit.
Any other recommedations? My current setup is attached.
Thank you very much for your time,
George
If the car is really stable you can go heavier on the rear diff. 30,000, you can also go from 5 to 4 on the droop. Going with more caster is not good if you want off power steering. Bringing the arms back will give more on power steering. If anything take away caster and also lay the front shocks back down. If the car gets loose with the heavier diff oil just put the front sway bar back on.
DJ Apolaro
Old 10-29-2008, 06:16 PM   #4204
dj apolaro's Avatar
Some people have been sending me PM's for my set-up. Here is my starting set-up for most tracks. It is stable with a slight push going in. It is how I drive. I drive with a slight push going in, with good corner speed and exit.
Regards,
DJ Apolaro
Old 10-29-2008, 10:05 PM   #4205
typer's Avatar
Regards,
DJ Apolaro
Sir i just purchased an east civic body for my snake. How do you find the body in terms of balance and feel?
typer is offline   Reply With Quote
Old 10-30-2008, 09:32 AM   #4206
dj apolaro's Avatar
It is good. Just mount the front wheels equal to the body and the rear wing back a little bit. Maybe 3mm off the rear of the body. The body has more steering than the 3.1 dodge, but is still stable. Play with the wing to get the stability.
DJ Apolaro
Old 10-30-2008, 10:49 AM   #4207
quietstorm76's Avatar
DJ Apolaro
Good info, thanks
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-30-2008, 12:12 PM   #4208
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Team Kamikaze View Post
Rafael,
He cant help that his hinge pin is limp
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 10-30-2008, 12:35 PM   #4209
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Micronips, see you in February!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 10-30-2008, 12:36 PM   #4210
nitrodude's Avatar
Wait! He HAS a hinge pin? I thought he needed hinge pins and pivot balls
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-31-2008, 03:04 PM   #4211
Suspended
Smile WASSSSUP
Nigel wasssssssup how is pop you guys commin for winternats
thats how you say AWSOME se ya
MICRONIPS LOL
Old 10-31-2008, 06:28 PM   #4212
MICRONIPS LOL
Fasho fasho. See you in Feb. Say hello to fam!
Old 11-01-2008, 08:41 AM   #4213
Pattojnr's Avatar
Trader Rating: 19 (100%+)
just finished painting up a new paint design today, for an upcoming race.
went for a snake theme. hope you like
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-01-2008, 05:21 PM   #4214
Doug M's Avatar
ssssssss..............Looks Great!....................sssssssss
Doug M is offline   Reply With Quote
Old 11-01-2008, 06:31 PM   #4215
s10dude's Avatar
excellent job............looks sweeeeeeeeeeeeeeeeeeeeeeeeet!
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
