Old 10-12-2008, 04:12 PM   #4171
s10dude's Avatar
bump..........news>?
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 10-17-2008, 09:05 AM   #4172
DJ,,very nice report on ROAR Nat's,,,thank you!!
s-733 red cup racing,twister tires,byron fuel
serpentjack is offline   Reply With Quote
Old 10-17-2008, 09:36 PM   #4173
dj apolaro's Avatar
Thanks,
Next time I will try to bring some Hardware home.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-17-2008, 09:52 PM   #4174
corallyman's Avatar
Trader Rating: 99 (100%+)
Very Nice showing DJ at the nats to you and Paolo. I was really hoping that you guys would go 1 and 2. You'll get them next time for sure. I really wanted to thank you though for the great report you posted for us to read. I know that takes time to do, so thanks for that!
Are you going to be sending in a set up sheet for that race to Serpent.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 10-18-2008, 04:01 AM   #4175
Is there gonna be an 09?
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 10-18-2008, 08:23 AM   #4176
fly_wheel's Avatar
heard the new 720-09 is coming next year... hopefully, just like 720 ~ 720-07 ~ 720-08... nothing much changes except some additional option parts...
fly_wheel is offline   Reply With Quote
Old 10-18-2008, 09:11 AM   #4177
dj apolaro's Avatar
Steve
I will send one in to get posted for you guys. It is not much different than my last set-up. However I did use a front diff this time (and liked it) and used less rear droop, and the #2 postion in the rear roll center. I also used the middle position for the front roll center. I went from 4 to 5 droop in the rear and 0 in the front. I also ran a lot more rear toe 3 degree. The front diff had serpent 80,000. The traction was very weird and I needed a more stable car. That is why I ran more toe in the rear, lower rear roll center and less droop for more stable breaking.
DJ Apolaro
Old 10-20-2008, 08:10 PM   #4178
Serpent720's Avatar
If you want your clutch to in-gage faster, do you need to tighten or loosen up the nut?
Serpent720 is offline   Reply With Quote
Old 10-20-2008, 09:10 PM   #4179
ceaz's Avatar
loosen, u might wanna check ur clutch gap and end play after.
Serpent 720
Fanatic Remote Racerz
Controlfreakz.com
Sponsored by: my checkbook
ceaz is offline   Reply With Quote
Old 10-20-2008, 09:12 PM   #4180
ceaz's Avatar
[QUOTE=fly_wheel;4952175]heard the new 720-09 is coming next year... hopefully, just like 720 ~ 720-07 ~ 720-08... nothing much changes except some additional option parts...[/QUOTE
i hope they dont change much, but then again. i am due for a new 720. lets see what happens..
Serpent 720
Controlfreakz.com
Old 10-24-2008, 05:43 AM   #4181
Pattojnr's Avatar
Trader Rating: 19 (100%+)
DJ Apolaro
hi DJ, i have just put a diff in mine, when i installed it, i notice only one guide for the belt on the geared diff. i shimmed out the inner layshaft pulley to align the belt better on the diff. did you do anything like that, if i didnt do so, the belt would run right on the edge of the teeth on the diff side. just curious ? cheers.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-25-2008, 07:50 PM   #4182
dj apolaro's Avatar
I actually used the guide from the one-way. I just reamed out the hole to make it fit (tight). I do not trust NOT using a guide. It is fine if you do not hit anything or get hit. I do not want to take that chance.
DJ
Old 10-26-2008, 03:59 AM   #4183
Pattojnr's Avatar
DJ
well i didnt have any problems with it this weekend. i checked it after every run, the belt stayed where is was first located. i had a few hits, no problems though. but still i like the car with the front swaybar disengaged. seems to provide better turn in, and with the diff, better again.
Serpent - Walter RC
Old 10-26-2008, 07:52 AM   #4184
gfilos's Avatar
Mr Dj Apolaro,
I need your help for a setup on the 720,
Our track is small, technical with low-to-medium speed, quick direction changes. The track is super flat, however the traction is rather low.
Can you please recommend me a setup to begin with? Mainly i am facing understeer problems at mid corner and corner exit.
My current setup is attached,
I would appreciate any help,
Thank you,
gfilos is offline   Reply With Quote
Old 10-26-2008, 09:19 AM   #4185
gfilos's Avatar
One correction, my main problem is oversteer and not understeer but generally the car seems to be unstable.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
