Old 10-01-2008, 07:28 PM   #4126
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
For the next race im going to adapt another foam bumper... Need to make it so that the space between the bumper and the body is minimum... Longer bumper means more impact absorption and less deflection on the body in a crash
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 10-01-2008, 08:59 PM   #4127
spurgear's Avatar
Send a message via MSN to spurgear
Originally Posted by Riketsu View Post
Can someone explain to me the difference between the EVO 1/0 degree blocks vs. the regular steering knuckles??? Someone has told me one of the EVO is just really the regular changed sides.... Someone enlighten me...
This is all i read about it
http://www.serpent.com/product/803212/
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 10-01-2008, 09:42 PM   #4128
Riketsu's Avatar
My question is here:
These new blocks have 1mm more offset compared to the standard versions, which gives the car a more smooth steering style.
It says these new blocks have 1mm more offset compared to the standard versions... 1mm more offset of which? the 1 degree or the 0 degree?
And after figuring out which gives the most degrees... what is the effect on the car???
Old 10-02-2008, 07:26 AM   #4129
Default 1 degre
1 degre is more initial stering
maxy is offline   Reply With Quote
Old 10-02-2008, 08:33 AM   #4130
dj apolaro's Avatar
The new blocks come in a 0 or 1 degree. You can choose which to buy. The 1 degree is basically similar to added 1 degree of caster.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-02-2008, 10:30 AM   #4131
Riketsu's Avatar
Thanks for the reply guys...
My other question is that it also says that if you find yourself in a high traction track... you can swap the 1 degree steering blocks from left to right and right to left... How many degrees you get there?? 2?
And last question is... first steering knuckles (Non-Evo) is the same as 0 degree Evo Steering Knuckles?
Thanks for the info
Old 10-02-2008, 11:16 AM   #4132
dj apolaro's Avatar
Thanks for the info
The 1 degree used flipped would be -1 and the 0 is the same as the other 0's
DJ Apolaro
Old 10-02-2008, 02:20 PM   #4133
jcrc's Avatar
DJ, the initial setup that you post earlier will work for a open, high traction and bumpy track. And what advice do you have for this type of track.
RC America / Xray, VP Fuel, Pit Lane Hobby
jcrc is offline   Reply With Quote
Old 10-02-2008, 02:43 PM   #4134
dj apolaro's Avatar
If the traction is high just disconnect the front sway bar. This will help over the bumps and also take out some caster. I use this setup everywhere to start.
DJ Apolaro
Old 10-02-2008, 03:07 PM   #4135
jcrc's Avatar
Thanks for your advice DJ, these weekend I will run my new 720 on our local track in Puerto Rico.
Old 10-02-2008, 04:45 PM   #4136
Ok, I'm going to jump in on this one. The first thing that you have to know, is what kingpin angle is. It is the angle formed between the upper and lower pivot balls within the steering block. This is not to be confused with camber angle. It is an angle that exists within the block. In the 0 degree block, the upper ball sits directly over the lower ball and the net angle formed is zero. In the 1 degree block, the upper ball is stepped back, and forms an angle relative to the lower ball of 1 degree.
I have prepared a drawing below that illustrates the relationships between the three steering blocks. The offset, is shown on the zero degree block, and is the same between the 0 and 1 degree block. If you could snap your fingers, and instantly change from the old block to either of the new blocks, you would wind up with 2mm wider track width. 1mm each side. The new blocks hold the pivot balls 1mm closer to the chassis, so to speak. It's not about shortening the upper and lower arms, it has to do with an increase in the distance between the center of the tire and the axis formed by the pivot balls. It holds the tire farther out. Affects scrub radius.
The original block has a kingpin angle of around .5 degree, so there is no correlation between the old block and either of the new ones. Relative to swapping left for right on the 1 degree blocks, you would wind up with a 1 degree positive kingpin angle. I'm not sure that that would be a good thing.
So what does all this mean? All I can tell you is that relative to full size racing cars, the more kingpin angle, the lower the difference in tire loading side to side. The lower the angle, the greater the tire loading on the outside, and the lower the tire loading on the inside. Greater differential side to side. It is a compex relationship between kingpin, scrub radius and caster.
I know we are all looking for that magic bullet that is going to give us that super car, but these are very subtle tuning adjustments. You are not going to change one thing, and see a vast difference in the car. Good handling is a complex mix of a number of subtle settings. There is an old axiom about car tuning: Changing one thing changes everything to some degree or another.
Changing steering blocks without having good spring and tire selections, for example, is like pissing in the wind. There are way more important things to be focusing on.
Nobody wants to hear it, but for the average R/C racer, the best way to improve lap times is by improving driving skills and maintaining a tight line.
Either of the new blocks are an improvement over the old one. I would say pick one and work with it. Your base setup and overall mechanical condition of the car are far more important. Being in a pinch, and not having one or the other, I have raced the car with different blocks on each side, and I contend that you would be hard pressed to tell the difference.
GLOWHEAD is offline   Reply With Quote
Old 10-02-2008, 06:53 PM   #4137
ceaz's Avatar
hey guys i need a little help here, what front and rear track width are u guys running on your 720, and also whats the best way of measuring it?
Serpent 720
Fanatic Remote Racerz
Controlfreakz.com
Sponsored by: my checkbook
ceaz is offline   Reply With Quote
Old 10-02-2008, 08:19 PM   #4138
gearhead_22's Avatar
Send a message via AIM to gearhead_22
you can use a hudy setup board or a digital caliper
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 10-02-2008, 08:54 PM   #4139
dj apolaro's Avatar
I start with front 198 rear 199
DJ Apolaro
Old 10-02-2008, 10:08 PM   #4140
Default less Serpent support-why?
I've noticed that Serpent is going through some changes. I'm having a hard time getting parts for it from my lhs as they no longer stock it. They tried getting parts for me from Serpent- but they too are getting the run around from Serpent in Miami.
With that said, I would like to buy the orange springs, but I'm not finding anyone selling them. Where are you guys getting your springs from. I've found many sites that sell parts, but no springs.
Any help would be great.
Thank you.
SerpNt1 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
