Old 09-29-2008, 09:56 PM   #4111
Arahawak's Avatar
Trader Rating: 32 (100%+)
Any kind soul/serpent experts could help?
what is the new spring color that is similar to the old orange springs from serpent. I am having a hard deciphering the numbers of the new springs.
Thanks in advance.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-29-2008, 10:11 PM   #4112
Team Kamikaze's Avatar
New spring colors don't have the same spring rate of the old springs.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-29-2008, 10:56 PM   #4113
Arahawak's Avatar
Thanks Sam.
So nothing from the new springs is close to the old orange springs. Lucky i have not ordered them.
Thanks again.
Old 09-29-2008, 11:33 PM   #4114
Serpent720's Avatar
Originally Posted by Erchur View Post
Serpent720,
I have used the Orion's Constant Pressure device for about three races now. I am running it at the factory recommended settings. This is my experience with it so far:
- The motor is consistent throughout the run (i.e., does not have the tendency to lean out as the tank is running out of fuel, Big Plus)
- Fuel consumption is higher at the recommended settings. I've noticed that with it the tank is almost near empty at the five minute mark (all other factors being constant). This is not good, but I believe I can remedy this by adjusting the pressure regulating setting.
- The device by design leaks oil, so there is quite a bit of cleaning after each run, and the pipe gets pretty dirty quickly. Since I am the type of guy that like his car clean, this is a real pain in my opinion.
So far I am willing to put up with the oil mess and as to the fuel efficiency I still need to play with the settings to improve it. I like the little gadget and will continue to experiment with it.
Since I just started using the device I am wondering how reliable it is and what its failure modes are. I guess only time will tell. Please let me know if anyone has had any experience with the device's failure mode.
I hope this helps.
Erchur
Thank you for your input Erchur. I've been debating if I should buy one or not. Will let you know.
Serpent720 is offline   Reply With Quote
Old 09-29-2008, 11:39 PM   #4115
SmoothSteady's Avatar
Here are the spring ratings from Serpent:
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
Old spring ratings
REAR N/mm FRONT N/mm
Orange 2,1 Orange 2,7
White 3,0 White 3,0
Yellow 3,8 Yellow 4,0
Red 4,6 Red 5,0
Blue 5,2 Blue 6,1
Purple 6,2 Purple 6,5
Grey 10,9 Grey 10,3
Cheers, Mark.
SmoothSteady is offline   Reply With Quote
Old 09-30-2008, 12:03 AM   #4116
fly_wheel's Avatar
Originally Posted by Arahawak View Post
Thanks Sam.
Thanks again.
look at ur chart..
fly_wheel is offline   Reply With Quote
Old 09-30-2008, 01:07 AM   #4117
Arahawak's Avatar
Originally Posted by fly_wheel View Post
look at ur chart..
Thanks. The chart is so much easier to read. Really appreciate it.
Now if only somebody can do something like this for the Mugen's Springs. *hint*
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
Old spring ratings
White 3,0 White 3,0
Red 4,6 Red 5,0
Blue 5,2 Blue 6,1
Grey 10,9 Grey 10,3
Cheers, Mark.
Thanks guys... it helped alot.
Old 09-30-2008, 08:46 AM   #4118
spurgear's Avatar
Send a message via MSN to spurgear
Anyone using the first set of non pro cvds? Ever notice this has allot of play in the bearing as compared to the fit of the stock dogbones? U think the new pro shafts fit the bearings better? I noticed this problem from the first day i built my car.
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 10-01-2008, 07:19 AM   #4119
Riketsu's Avatar
Send a message via AIM to Riketsu
Can someone explain to me the difference between the EVO 1/0 degree blocks vs. the regular steering knuckles??? Someone has told me one of the EVO is just really the regular changed sides.... Someone enlighten me...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 10-01-2008, 10:31 AM   #4120
didrace's Avatar
Default Dj alperto
Hello there,
I am new to this forum and i have made a recent thread named "Guys i need help from experienced drivers"..
all of the guys were very helpful..they told me to buy the xxxmain book to make my 720 run well...
they told me that there is someone called dj alperto and he is very good and helpful..
basically my 720 07 is a car that whatever i tried on it the thing is nervous and unforgiving..and i asked if i buy the new kyosho or the nt1 will it be better..
in the thread i made they gave me a link of the 720 going amazingly good and thats how i want my car to be...
the car there seems very forgiving and it goes like a train..
didrace is offline   Reply With Quote
Old 10-01-2008, 10:32 AM   #4121
didrace's Avatar
Oh yeah,
and someone told me that the serpent cars brake plastics more easily than kyosho and mugen..
is tha true?
Old 10-01-2008, 10:43 AM   #4122
The 720 08 is a very tuff car, the only time ive broken it is when ive let the tires go to low and in a high speed sweaper i skated out to the wall going about 60mph and hit the wall, and in this accident(my fault by the way) i only broke a hub carrier and lost a spring retainer. Both of the new cars 960 and 720 were improved in durability and made more user freindly(easier to work on). Both of these cars can deliver when it counts, two of the best cars on the market.
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 10-01-2008, 10:46 AM   #4123
I think a few pages back DJ has a very good set up already posted!
Jeremy Cupps
Sponsors are
Old 10-01-2008, 12:40 PM   #4124
dj apolaro's Avatar
Originally Posted by didrace View Post
Hello there,
Hi didrace,
Let me introduce myself. My name is DJ Apolaro and I am a factory driver for Serpent. I have a post earlier #4049 that may help you. If you ever need anything just ask here as I check it daily. You can also send me a PM. There are plenty of people willing to help in the serpent 720 forum, just be patient.
Regards,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-01-2008, 06:48 PM   #4125
Erchur's Avatar
didrace,
I have run the MTX4, VRRR in the past and have been running the 720-08 for almost a year now. My experience is that the plastic parts on the 720 do have the tendency to break easier relative to the MTX4 and VRRR when in a hard crash against the wall .
This is not necessarily a bad thing, in fact it is good; this is why in my opinion. While the MTX4 and VRRR plastic parts hold up better in a hard crash, these two cars have the tendency to bend the chasis easier than the 720. The 720 plastic parts do absorb much of the energy of the crash while breaking, which is not transfered to the chasis, thus avoiding it getting tweaked.
I have broken a fair share of 720 right lower control arms and left rear lower control arms and pins, but I have not ever had to replace a tweaked chasis on my 720. I much rather replace a $6 plastic part than a $90 chasis (which I did a few times $$$$ with the MTX4 and VRRR).
All three are good racing cars and each has its own peculiarities. I happen to like the 720 becasue the car is light, fast and easier to maintain in top racing condition.
Erchur
p.s., BTW, after almost a year of running the 720 I am still using the original belts, while I had to the replace the belts in the VRRR every other race ($$$$).
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
