Old 09-05-2008, 06:33 AM   #4021
s10dude's Avatar
Originally Posted by mc_chofo View Post
can u tell me how much at end play? .5, .4? or less? my problems begun when i changed my engine i think that might be my probme, longer stroke, i think i have to use less endplay
i don't measure my end play , i just make sure it spins freely and does'nt move back and forth much..probably about .1
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 09-09-2008, 11:21 AM   #4022
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Can anyone answer this. I have my 720/08 and I got a set of new springs and in the manual it shows that you use front springs in the rear also, when I did that I can not get ant ride hight. the shocks are the same length.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 09-09-2008, 11:29 AM   #4023
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I think the spring length is different. Which is why you may not get the height yo uwant.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-09-2008, 12:11 PM   #4024
Derby Bros Racing's Avatar
Use rear springs (longer) in the rear.
Derby Bros Racing is offline   Reply With Quote
Old 09-09-2008, 12:41 PM   #4025
that's what I have been using I was just wondering why the manual showed using front on the rear.
Juwan Hunter
Old 09-09-2008, 12:43 PM   #4026
Must have been a typo...
Old 09-09-2008, 04:42 PM   #4027
s10dude's Avatar
i use front's all round but i changed the retainer clips in back for more spring height...easier to use all same spring's at race...no mix up in height..there is one set of clips that has longer height than stock ones in box .ther not the smooth ones they are the ones w/X or cross bars on bottom..
Old 09-09-2008, 05:10 PM   #4028
thanks I know the ones you are talking about
Juwan Hunter
Old 09-09-2008, 05:19 PM   #4029
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i got my 720 used. when setting it up, i found i could only get about -5 mm rear droop using droop blocks. looked in the manual, said each shock should be 68mm length front and rear. i couldnt get any more droop out of the rear like this. so i lengthened them to 70mm but the amount of thread wasnt strong enough at the shock end. so now i got a set of long shock shafts in the rear shocks, with the long spring set, and i can now go as much as -1 droop on the rear . but i set it up at -3.
shock length now is 72mm.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-09-2008, 05:24 PM   #4030
Riketsu's Avatar
Yeah, this happens... The fix like you mentioned is either longer shock shaft (From 960), or longer shock case (From 960), or both.
Old 09-10-2008, 11:24 PM   #4031
hi i'm trying to make my own centax 3 shoes, but i red i don't remember where that a great material to do that was Rulon, but since i can not find it here i have tought in Nylamidİ 901, and i just saw a murnan's website a centax shoe that looked like Celoron also know as Micarta, durante, Dilecto. i don't know if you have seen this Celoron it's a material that looks like wood but it's not wood which is used mostly for big machine gearing. wha do u think, or the best thing is keep using the yellow shoes from serpent?
mc_chofo is offline   Reply With Quote
Old 09-11-2008, 05:27 PM   #4032
Garaski's Avatar
If you have the time to make your own then it's always nice to experiment.
Team Kamikaze
www.kamikazercracing.com
Garaski is offline   Reply With Quote
Old 09-11-2008, 09:51 PM   #4033
fly_wheel's Avatar
i know celeron is from intel, duratec is from audi (or ford, i've forgotten), n pyramid is in egypt..! jk, dun b mad...
fly_wheel is offline   Reply With Quote
Old 09-11-2008, 10:08 PM   #4034
spurgear's Avatar
Send a message via MSN to spurgear
Might be a stupid question but im trying to fully understand clutch end play. Now if u all set ur end play as suggested and u fully assemble ur clutch back together . Say for example im looking at ur car, can i with my hand physically move the bell about in and out about 0.5mm? Im just wondering if my clutch is set wrong all this time. Will explain more when someone answers. thanks!
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 09-11-2008, 10:12 PM   #4035
spurgear's Avatar
Well there is always the optional shoe from serpent. The red one. Also i see zeppin racing has their optional ones. Im not sure its from a different material. Check it here
http://rc-mushroom.com/advanced_sear...6999aa&x=0&y=0
East Civic 200mm
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
