Old 08-25-2008, 07:49 AM   #3961
fly_wheel's Avatar
Originally Posted by Pattojnr View Post
i had my second outing wiht the car yesterday, and im close to having this absolutley dialled in. i TQed for the day, missed the start in the 10 min race and finished 1 second behind 1st. the 15 min main , i had problems in the warm up, and the car was very undrivable. a quick inspection didnt see any belts missing or teeth. so i continued on. missed the start again, and finished in 3rd place. afterwards i found a missing left hand CV. so a 3 wheel drive car for 15 mins. ill get a setup sheet organised during the week, and whoever can try it and see how it goes for them.
care to share ur 3wd car setting???
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 08-25-2008, 08:08 AM   #3962
Pattojnr's Avatar
Trader Rating: 19 (100%+)
lol thats funny the setup is preferably with all dog bones and CV,s fitted and working. just trying to finish up the 960. so ill get the setup shortly.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-26-2008, 11:06 PM   #3963
hello, i just was driving and lost radio and my car flew like 5 mts on the air, and i bend my 720 lcg chassis, not much, it's almost straigt, the bend starts where the front bulkhead begins, and continues to the tip of the chassis, at that point of the chassis the hight from the bottomb of the chassis to the bended tip it's only like 3mm, so do any of you know a safety way to straighten bended chassis?
mc_chofo is offline   Reply With Quote
Old 08-26-2008, 11:22 PM   #3964
Team Kamikaze's Avatar
Rodolfo,
You can try hammering it against a piece of wood, and try to straighten it the best you can, it's hard but it's worth trying it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-26-2008, 11:33 PM   #3965
hammering with a rubber hammer or steal hammer? Sam what do you think about putting it on a press(and think that's how it's called) and pullit till it gets straight, the thing is that i don't want to mess the chassis completely.
Old 08-26-2008, 11:53 PM   #3966
Just do it a little at a time, you got nothing to loose, it is already bent to begin with, by the way, you already have a new chassis on it's way.
Old 08-26-2008, 11:57 PM   #3967
nitrodude's Avatar
What you want to do is set the chassis on your droop blocks, set the blocks about 3in apart with the bend in the midlle of the 2 blocks, then hit it with a hammer. When yoiu hit it you have to bend it back farther than the bend itself because otherwise it springs back to bent. Bend it back a little at a time.
Make sence?
I would just buy another chassis, it might be tweeked too, you never know
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-27-2008, 12:26 AM   #3968
He already did
Old 08-27-2008, 01:29 AM   #3969
rcabj's Avatar
Default bent chasis
well...just bend it a little at a time, or the safest way is to put the chasis between 2 pieces of a flat wood/material ( like a sandwich) and use the grip vise clamp and leave it there overnight.
i learn it the hard way...i and broke it for good
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 08-27-2008, 03:56 AM   #3970
Pattojnr's Avatar
is there an editable setup sheet for the 720 ? printer needs replacing, so i cant print out a sheet to fill in. maybe if there is one i can edit and post.. cheers.
Serpent - Walter RC
Old 08-27-2008, 04:44 AM   #3971
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
How much are you guys setting your gap to with the Novarossi???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-27-2008, 04:52 AM   #3972
Pattojnr's Avatar
talking about clutch gap ?
i used 0.4 gap on the weekend, minimal endplay. i wound the clutch spring till it started slipping and took it back one turn. was very consistent feel all day. overall happy with changing from the TM.
Serpent - Walter RC
Old 08-27-2008, 10:45 AM   #3973
fly_wheel's Avatar
maybe pre heating it will makes ur job easier... aluminium tense to have minor cracks if its being bend... pre heating it may help u eliminate cracking problems... good luck...
Old 08-27-2008, 06:01 PM   #3974
s10dude's Avatar
pre heating will also make the aluminum soft ....permanently!
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 08-27-2008, 06:10 PM   #3975
Derby Bros Racing's Avatar
I don't know about making it soft. When I run my car the chassis gets to about the same temp as the motor. 130dF asphalt (yes normal here in the desert and other hot places) and 260dF motor. Temp your chassis sometimes, you'll see what I mean.
Anyway, the bent chassis will not go back to how it was when new. The best way to try to straighten it so you can use it for the meantime is to get a couple of 4x6 wood (a little bit longer than the chassis itself of course). Sandwich the chassis, put it on the ground and run it over with your car (your real car!). Leave everything underneath the tire overnight. The next day you have a straight chassis.
Derby Bros Racing is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
