Serpent 720
Old 08-22-2008, 04:28 AM
  #3946
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Originally Posted by DS Motorsport View Post
i can confirm everything stefan is saying.
I live close to the factory and heard the entire story from first hand.
Parts are real scarse right now and so are
engines and xceed tyres.
But i think serpent will make it, ronald and micheal are really determind to make it work.
Serpent better find a way to pay those bills to those Asian factories, or there will be no parts.........And this company isn't the only one in trouble...
fastharry™ is offline
Old 08-22-2008, 07:19 AM
  #3947
Team Kamikaze's Avatar
Originally Posted by Pattojnr View Post
what are the size of these bearings ? i have some 8x5x2.5 coming. i take it you use 2 of these on the outer bearing. or the other option is 8x5x3 , i went for the 2.5 and i got some shims incase.
5x8x2.5 are flanged bearings which are used for the side belt tensioner, you should get the 5x8x3.
Team Kamikaze is offline
Old 08-22-2008, 07:47 AM
  #3948
Pattojnr's Avatar
Trader Rating: 19 (100%+)
thanks Sam. ill be heading to LHS in the morning to get them. cheers again
Pattojnr is offline
Old 08-23-2008, 06:36 PM
  #3949
spurgear's Avatar
Can someone please confirm which bearings will work for the WC clutch? So far everyone is saying different sizes. The #1311 recommended by DJ Apolara is different from the one Team Kamikaze recommends. Anyone have any official document for the part number for the bearing?
spurgear is offline
Old 08-23-2008, 06:56 PM
  #3950
The WC clutch bell needs 2 kinds of bearings, one 5x10x4mm and two 5x8x3mm and part #1311 contains 2 pieces of 5x8x3mm bearings.
Old 08-24-2008, 05:06 AM
  #3951
Pattojnr's Avatar
that part number has 2 bearings in it. 5x8x2 ?
Pattojnr is offline
Old 08-24-2008, 07:00 AM
  #3952
Yes part #1311 contains 2 pcs. 5x8x2mm not 5x8x3mm as I mentioned earlier, but the bearing I use for the WC clutch bell actually measured 5x8x2.3mm (as long as it is not a flanged bearing). sorry for the confusion.
Old 08-24-2008, 07:05 AM
  #3953
Trader Rating: 18 (100%+)
I have a stupid question how do i identify the the tooth count on my serpent 720 spurs gears i am wanting to change them up a little but i dont see any numbers am i missing something
icantdrivetc5 is offline
Old 08-24-2008, 08:14 AM
  #3954
Mark 1 tooth as a reference and start counting.
Old 08-24-2008, 08:34 AM
  #3955
thats why i went ahead and said dumb question thanks time to start counting
Old 08-24-2008, 11:50 AM
  #3956
fly_wheel's Avatar
hope u don't misscount ur spurs...
fly_wheel is offline
Old 08-24-2008, 02:22 PM
  #3957
Riketsu's Avatar
Trader Rating: 33 (100%+)
What kind of spurs you have? WC or LC? I have the LC and they are marked with a number...
Riketsu is offline
Old 08-24-2008, 04:11 PM
  #3958
Pattojnr's Avatar
there are numbers stamped into the plastic. the WC gears are marked with the full number. the LC gears are marked with a single digit. this single digit refers to the last number on the tooth count. so if its marked 1 for 1st gear, it refers to 61, 0 = 60, 9 = 59. same for second gear.
Pattojnr is offline
Old 08-24-2008, 04:29 PM
  #3959
Pattojnr's Avatar
Default second outing with the car
i had my second outing wiht the car yesterday, and im close to having this absolutley dialled in. i TQed for the day, missed the start in the 10 min race and finished 1 second behind 1st. the 15 min main , i had problems in the warm up, and the car was very undrivable. a quick inspection didnt see any belts missing or teeth. so i continued on. missed the start again, and finished in 3rd place. afterwards i found a missing left hand CV. so a 3 wheel drive car for 15 mins. ill get a setup sheet organised during the week, and whoever can try it and see how it goes for them.
Pattojnr is offline
Old 08-24-2008, 07:29 PM
  #3960
spurgear's Avatar
Thanks!!
spurgear is offline
