Serpent 720
Old 08-01-2008, 01:29 AM
  #3856
Shuhakimi's Avatar
Originally Posted by fly_wheel View Post
maybe the only choice is to buy their limited edition F1 rc car as it comes with a very large n nice bag... the nicest i've seen so far...
Hmmm ...I owned one, it's OK but the compartment is so simple BUT the fabrication.......damn nice
Shuhakimi is offline
Old 08-01-2008, 07:35 AM
  #3857
Team Kamikaze's Avatar
Originally Posted by shmoot View Post
does anyone know where i can get the Serpent large pit bag?
It is on the works! will soon be released, have patience.
Team Kamikaze is offline
Old 08-06-2008, 07:05 AM
  #3858
fly_wheel's Avatar
what do u guys usually run at front, spool/diff/one way??? is ther any major change of setting needed when testing these front drivetrain??? thanks...
fly_wheel is offline
Old 08-06-2008, 07:35 AM
  #3859
dj apolaro's Avatar
I run a lock. It is the most consistent, however has the most push. You have to play with weight transfer a lot more with the lock front.
DJ Apolaro
dj apolaro is offline
Old 08-06-2008, 09:01 AM
  #3860
DJ over a year ago you gave me a set up for the 720 to try. Well I finally tried it and it works great. Don't know why I didn't try back then.
Now, only if I could drive \
RoyU is offline
Old 08-06-2008, 10:04 AM
  #3861
dj apolaro's Avatar
Driving will come with more practise. Glad you like the set up.
DJ Apolaro
Old 08-07-2008, 03:31 AM
  #3862
fly_wheel's Avatar
if i decrease rear down stop, will it decrease weight transfer??? btw, how to i adjust the rebound of the rcc shocks??? i ran out of idea, i just rebuild n run them no matter how they are at the moment... in both my 720 n s400...
Old 08-07-2008, 06:06 AM
  #3863
nigelnuggets's Avatar
Having a lower value on the droop tools means more droop.
more droop, or upward travel on the chassis, increases weight transfer to the front of the car. Meaning, more steering under braking conditions or at any point where deceleration occurs.
nigelnuggets is offline
Old 08-08-2008, 03:28 AM
  #3864
fly_wheel's Avatar
thanks, i always get tail out while turn in... i guess i have to try to decrease rear droop...
Old 08-08-2008, 05:35 AM
  #3865
3.5mm above ride height in the rear is what seems to work good for me. I've tried different and always go back to 3.5mm.
I always play with the front 1mm and 1.5mm above ride height. Depends if I need more weight transfered to the rear of the car on corner exit.
SRW141 is offline
Old 08-08-2008, 08:24 AM
  #3866
border r/c's Avatar
Hi,
if you want to buy a present for you're kid
look here
its almost X-mass
border r/c is offline
Old 08-09-2008, 08:42 PM
  #3867
shmoot's Avatar
Trader Rating: 17 (100%+)
DJ Apolaro
hi DJ...ive tried the setup u gave me on two tracks here and it works great thanks. The only thing Ive changed is running a spool and change using the brass plate instead of carbon on my LCG chassis. Ive since able to get rid of understeering issue and the setup really suit my driving style. Thanks man! Now to test it out under racing condition.. wish me luck.
shmoot is offline
Old 08-10-2008, 12:31 AM
  #3868
ProE's Avatar
What happens to the handling of the car if you change from the Brass chassis insert to the CF insert?
ProE is offline
Old 08-10-2008, 05:29 AM
  #3869
razzor's Avatar
It should only change your center of gravity and front to rear weight distribution a bit.
razzor is offline
Old 08-10-2008, 06:59 AM
  #3870
dj apolaro's Avatar
Good to hear. I do not any inserts in the chassis. I like having the flex in that part of the car. It helps in high bite.
DJ Apolaro
