Old 07-21-2008, 12:54 PM   #3826
Hyde's Avatar
so I'm geussin none of the parts fit the impulse. you guys must think the serpent impulse is old trash
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 07-21-2008, 01:13 PM   #3827
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by LATC3 View Post
do any parts fit the impulse
the only thing that will interchange with the 720 is the tires.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 07-21-2008, 01:16 PM   #3828
Originally Posted by Serpent720 View Post
On my 720, the rear belt keeps riding the edge of the gear. Should I move the small gear a little? If I do, the belt seems to rub the edge of the small gear lip a little.
my belt rides at the same spot. Got car in april and haven't had any problems. I love this car
Juwan Hunter
Old 07-21-2008, 01:30 PM   #3829
Hyde's Avatar
could i pm someone for some advice?
its about ebay/serpent impulse.
PLEASE!
Old 07-21-2008, 01:34 PM   #3830
PLEASE!
what do you need?
Juwan Hunter
Old 07-21-2008, 07:55 PM   #3831
ShermanSim's Avatar
Try loosening up the belt tension, might be a little tight.
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 07-22-2008, 03:06 AM   #3832
etgdpu's Avatar
Hello to all,
A few pages backwards, I asked for centax setup and Paolo replied with the following.
Originally Posted by Paolo M View Post
I use only MF, so i have quite some experience with them. I like the cluth this way
Std flyweigths pivoting
yellow shoe
0.8mm gap
0.2 mm end play
hard grey spring 1.8 mm (909518) preload to 1.5mm or black hard spring 1.8mm (909520) preload 1.0mm
Works good for me!
I would like to confirm that this setup worked fantastically good for me and is exactly what I was looking for. Thanks once more.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 07-23-2008, 06:50 PM   #3833
intimidator's Avatar
Just got a used 720,dont feel like reading all these pages so please dont tell me to look back in the pages.What are this cars weak points,must have option parts,anything particularly weird,anything you guys can give advice on this car.Latc3 pm me if you havent any answers to your questions about the impulse,I ran that car when it first came out with a single speed side exhaust,had one forever know that car inside and out.I actually know where to get new parts,used cars,etc..
intimidator is offline   Reply With Quote
Old 07-23-2008, 06:56 PM   #3834
Wink
Weak points are rear arms / front bumber / spurs /pinion
IMHO but maybe i'm just a lousy mechanic/driver
Serpent 720/08-Spektrum control-Maxpower- Hitec steering
lobotm is offline   Reply With Quote
Old 07-23-2008, 07:01 PM   #3835
Spur gears, replace pinions when they get sharp, I would get a couple front bumpers, front upper and lower arms, rear arms. Also extra cvd's.
The only thing I seem to rip up is spur gears.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-23-2008, 07:32 PM   #3836
Dont serpent make a body designed for lola bodies that is a lot tougher looking than the one in the kit??Yeah the cvd are weak as could be the used kit i got has regular bones in the car but the previous owner gave me the cvd shafts as well,but they are all busted,gotta take a better look hope i just need new shafts.
Old 07-23-2008, 07:37 PM   #3837
rcabj's Avatar
weak points or parts?? i do not think there is any if u mean they suddenly break without any proper causes . breakage resulting from impacts is a different matter in my opinion. but there is wear and tear issue , for this regular maintenance or servicing is required in order to keep the car at its best performance. it's been a year with the car and nothing unusual. no options used and nothing weird so far.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-24-2008, 05:35 AM   #3838
s10dude's Avatar
there are no weak points , unless you hit something then your going to break something ....lol....CVD's break fairly easy...i still have my original pinion's after 8 month's...( and they are fine...)
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 07-24-2008, 08:10 AM   #3839
fly_wheel's Avatar
hardly will wear out pinions or spur unless setup wrongly... ready some front upperarms as they tends to wear slightly faster then the rest... trust bearing n clutch maybe for spares. never broke cvd without a hard impact, but hey u might broke anythng with hard impact...
so hereis the list:
front upper arms - wear n tear (never broke 1)
front arms - wear n tear (never broke 1)
rear arms - wear n tear (broke 1 when i broke my 2spd shaft too, very hard impact)
cvds - spares as the pins might wear
clutch assembly, shoes, bell, housing, etc - spares, wear n tear
belts - wear n tear
trust bearing - wear n tear
spurs n pinions - ratio option
springs - dampening option
sponge for RCC shocks - future maintenance
some other plastic parts too for spares if u live far from parts source... thrust bearing n clutch assembly depends to individual as i might wear them too fast as i'm not good in engine tuning... the 720 is fairly bullet prove now... the new SPP spring steel CVDs r great option too...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 07-24-2008, 08:28 AM   #3840
Sow&Steady's Avatar
Its a tough car that's for sure. As for "age" or "generation", here goes :-
Impulse
Impulse Pro
705
710
720
The top 3 have most interchangeable parts.
The 720 has most of its Centax and 2-speed clutch. Shocks too probably that you can use with the Impulse. Other than that no .. I think ..
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
