Old 06-28-2008, 06:03 PM   #3751
spurgear's Avatar
Send a message via MSN to spurgear
I have the stock gearing 1st gear (59T/17T) and second (57T/23T) on my 720 and i would like to convert to the WC transmission. So all i need is a clutch bell and pinions/spurgears?
Also i noticed they dont make the same gearing for the second in WC. Would the closest to my stock be (56T/23T)???
Anyone knows if this will mesh? Anyone have a chart?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 06-29-2008, 01:29 AM   #3752
rcabj's Avatar
Originally Posted by spurgear View Post
Quick question
Before i use the setup station on the car. I have to set the ride
height. I never used the green setup wheels without the tires that
came in the serpent kit. And my friend says he uses that to set his ride
height in his NT1.
How u do it?
I basically use a new set of tires. Is that the purpose of the green
wheels? Wouldnt his way be inaccurate?
well, basically i set the ride height depending on tyre diameter and how long the mains is. the main purpose is to keep your car from bottoming at the later stage. each time i change tyres esp. with different diameter i set them again.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-01-2008, 07:11 AM   #3753
etgdpu's Avatar
Hello all,
I would appreciate if you explained the difference in car handling between the plastic and the metallic X bracket.
Thanks in advance
Dimitris
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 07-01-2008, 08:12 AM   #3754
Originally Posted by etgdpu View Post
Hello all,
Thanks in advance
Dimitris
I would think that the plastic "X" brace would let the chassis flex more and give you more steering. I have never always ran the alum. one. I have heard cutting the alum. one in half gives you alot more steering.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-01-2008, 08:44 AM   #3755
dj apolaro's Avatar
I use the aluminum brace and cut it in the middle. I think it gives the correct amount of flex and helps the car steer more, but stay stable. I also do not use the middle screw on the left graphite brace that the side belt tensioner is on. I cut that area away so the graphite does not touch the alum brace. Hope I explained myself well enough for people.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 07-01-2008, 08:52 AM   #3756
etgdpu's Avatar
Thank you guys.
Old 07-01-2008, 09:58 AM   #3757
DJ Apolaro
Why would you spend money on the aluminum x brace then cut it in the middle? should have just stayed with the plastic one, which will function the same.
ich weiß
hello is offline   Reply With Quote
Old 07-01-2008, 10:37 AM   #3758
which part of the graphite? top or bottom at the alu brace or to the rear left bulkhead?? thanks
DJ Apolaro
ck960 is offline   Reply With Quote
Old 07-01-2008, 10:45 AM   #3759
DJ Apolaro
Hi Dj,
thus, you cut the "X" in the middle ? and how many mm do you cut it ?
and also, why do you cut the graphite ? what is the effect ?
thank you very much for your advices!
Manu_05' is offline   Reply With Quote
Old 07-01-2008, 03:14 PM   #3760
SERPENT CURACAO's Avatar
Send a message via MSN to SERPENT CURACAO
Default side belt tensioner
Like this it should be
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
MAXY'S MODIFIED ENGINE
SERPENT CURACAO is offline   Reply With Quote
Old 07-01-2008, 03:22 PM   #3761
Default this is the x
like this it should be
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
Old 07-01-2008, 03:28 PM   #3762
thanks
you cut just the left of the graphite and not the right ?
Old 07-01-2008, 03:38 PM   #3763
dj apolaro's Avatar
They do not respond the same. Trust me when I tell you I have tried every way possible and the way I use it works best for me. I find that I am able to carry more corner speed with stability my way. The diagram that was posted with the graphite cut is not the way I use it. I tried that way and liked mine better. I cut the graphite at the upper part of the aluminum brace. It is still connected in the bottum and rear. Hope this helps.
DJ Apolaro
Old 07-01-2008, 03:39 PM   #3764
dj apolaro's Avatar
Originally Posted by Manu_05' View Post
thanks
Just the left one.
DJ Apolaro
Old 07-01-2008, 03:56 PM   #3765
Dj whats up the pictures are the style that maxy did it for me the way you did i did it too and workd good too
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
