Old 05-29-2008, 10:16 AM   #3661
Doug M's Avatar
Originally Posted by dj apolaro View Post
I think the pinions do not work with the old gears.
DJ Apolaro
The new WC pinions and WC spur gears cannot be mixed with the current pinions and spur gears.
To switch to the new WC gears and pinions, when they become available, with a minimum of parts you will need 1 each of the following.
803231 Centax-3 clutch housing wc
1311 5x8 bearing
1315 5x10 bearing
803232, 802233, 802234 or 803235, 16t to 18t 1st gear pinion wc
803236, 803237 or 803238, 21t to 23 23t 2nd gear pinion wc
803222, 803223, or 803224, 54t to 56t 2nd gear spur gear wc
803225, 802226, or 802227, 59t to 61t 1st gear spur gear wc
Doug M is offline   Reply With Quote
Old 05-29-2008, 10:20 AM   #3662
Doug M's Avatar
Default Homestead Set Up?
DJ, you were so fast at the Super Regional at Homestead RC Raceway that a lot of racers are asking for your set up for this track. Any chance you could share or direct the racers to a link for this info?
PS: Good luck at the 301 Capitol Classic!
Old 05-29-2008, 11:03 AM   #3663
Trader Rating: 16 (100%+)
Originally Posted by SRW141 View Post
I setup my ice charger for .6 w/ peak detect set at 3mv to charge my receiver pack. It took around 1800 seconds and only took 63 mah of charge. This doesn't seem right.
3 delta peak is for those batteries are in top shape (like matched cells for EP cars) and is in its top condition. For your receiver packs, and especially if your pack has been sitting for awhile or so...start from 7 delta and keep going down.
From my understanding (correct me if I am wrong)...the older the pack, the higher # of delta peak so the charger can get a higher value to prevent faust peak...if your pack is a team match top of the line batteries, you use lower delta peak.
I set my whatever years old 750 mah AAA @ 5 delta peak all the time and use 1C charging (0.75 amps) Lower the better...usually run time is longer.
Old 05-29-2008, 11:09 AM   #3664
Thanks for the info. I will try it. I have one pack on my KO wall charger. But have a 2nd pack that I charge with the Ice charger.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-29-2008, 12:45 PM   #3665
dj apolaro's Avatar
Here you go. Please ask if you have any questions.
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-29-2008, 03:53 PM   #3666
Doug M's Avatar
Thanks DJ!
Old 05-30-2008, 06:49 AM   #3667
s10dude's Avatar
yes...this is what i was talking about...great info......
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-30-2008, 09:07 AM   #3668
DJ Apolaro
yes, that`s right
http://www.serpent.com/product/803230
ciao
serpentmaster is offline   Reply With Quote
Old 05-30-2008, 10:52 AM   #3669
Default Setup Sheet
Some of my friends didn't know there was a more current setup sheet.
You can get it here.
http://www.serpent.com/file.php?FileID=4907
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 05-30-2008, 04:16 PM   #3670
thinking of running S&S tampa,can i get away with a 17/23 pinion there, any720 help,, runnin DJ's Fort setup, thanks
s-733 red cup racing,twister tires,byron fuel
serpentjack is offline   Reply With Quote
Old 05-30-2008, 05:56 PM   #3671
Sow&Steady's Avatar
Again this one also does not have track width or am I missing it somewhere?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-30-2008, 06:57 PM   #3672
s10dude's Avatar
i don't see a specific spot for track width.......i just printed it out....
Old 05-30-2008, 08:33 PM   #3673
roadrage's Avatar
Trader Rating: 14 (100%+)
At ss race way i use 17/22 61/56. a 23 is to long of a gear for that track. with the 22 56 you will have plenty on the str8 and enough get up through the end field.
Austin
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 05-31-2008, 02:25 AM   #3674
Sow&Steady's Avatar
Thanks for veifying that dude ... when I saw that it was missing in the original 720 sheet, I thought it was a mistake but now that even the updated one for the 720-08 is missing this I thought maybe I've been looking at too many setup sheets and my eyes are crossed! LOL!!!
Ah well, back to the notes area I guess.
Old 05-31-2008, 08:02 AM   #3675
Austin
thanks Austin..
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
