Old 05-26-2008, 02:24 PM   #3646
Team Kamikaze's Avatar
Originally Posted by SRW141 View Post
Thanks Sam for the info.
I have a ice charger. It goes from .1 to 8 amps and zero mv and up. I guess I could use my Ko wall charger that I have for my radio.
Hope to meet you at the Classic.
Yes, your KO wall charger for TX and RX will work just fine, see you at the classic.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-26-2008, 03:24 PM   #3647
Winner's Circle's Avatar
Default Kyosho CVDs in a Serpent 720
The Serpent 802350 CVD has a reputation for easily breaking. Also, it is currently on back order from Serpent. I did a little research and found that some of the Serpent 720 Team Drivers are using the Kyosho CVDs in their cars. The ball on the Kyosho Cvd requires some grinding in order to get it to fit into the Serpent dog bone driver. The Kyosho part is holding up well. I have them in stock = kyvsw006 is the part number.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 05-26-2008, 03:36 PM   #3648
gearhead13's Avatar
Why doesn't Serpent maintain a site with uploaded setup sheets like other manufaturers? Like Xray.
Or is there a site out there that i havent found yet?
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 05-26-2008, 04:33 PM   #3649
Sow&Steady's Avatar
They used to but stopped for some reason. I have some on my website 3hobby.net but they are mainly for the BRCA Nationals by top UK Serpent driver Mark Green.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-26-2008, 04:36 PM   #3650
s10dude's Avatar
use your ice and set it at.6 ( which is .60 .just over1/2 amp) and your battery will luv you for it.......
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-26-2008, 07:18 PM   #3651
dj apolaro's Avatar
I choose to help people directly on this site and through my PM, which is always busy and I check it often. However serpent does have a spot on their site under racing and then setups. Here is the link
http://www.serpent.com/racing/setups/
Regards,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-27-2008, 10:16 AM   #3652
I see the centax III and spur gears are getting an upgrade.
Pulled from Redrc.net
Serpent have introduced a new WC version of their Centax III clutch system and updated 2-speed gearbox system. The updated transmission uses the same pitch as before but has an improved tooth profile, which combined with a wider spur and pinion gear, gives better contact for better durability and power delivery. The steel clutch bell housing has also been updated with the pinions no longer forming the structure of this area but are instead attached the steel threads on the new bell. This ensures that the gears spin true and are much more resistant to any flexing in this area. As a result of this new bell, the front 2 bearings in the clutch have been changed and are now smaller in diameter compared to previous versions. The new WC transmission cannot be used together with the original spurs or pinion gears. A full range of spur gears (54T-56T, 59T-61T) and pinions (16T-18T, 21T-23T) are available separately.
Serpent 720-serpent-clutch.jpg   Serpent 720-spurs.jpg   Serpent 720-clutchbell.jpg
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 05-28-2008, 04:59 AM   #3653
redsand's Avatar
Send a message via Yahoo to redsand
The ones that are easily break are made by 3Racing. Do you have a link to back up your "little research" ?
redsand is offline   Reply With Quote
Old 05-28-2008, 08:49 AM   #3654
Sow&Steady's Avatar
Regards,
DJ Apolaro
Thanks for the link DJ ... pity its a little "quiet". But I agree with your efforts in helping others directly on this forum.
Old 05-28-2008, 12:14 PM   #3655
Dreddlox's Avatar
I look for my answers here on the Tech forum. DJ, Paolo and others here have made themselves available for Q&A on setups gearing and what have you. God bless RCTech.
Dreddlox is offline   Reply With Quote
Old 05-28-2008, 12:42 PM   #3656
Wow, I think you are just trying to sell your kyosho cvd shafts just because you are out of the Serpent original CVD shafts, what a mickey mouse you are, anything that needs to be ground down to fit will make the part weak,
as REDSAND said "The ones that are easily break are made by 3Racing" now to repeat redsand's question, Do you have a link to back up your "little research" ?
hello is offline   Reply With Quote
Old 05-28-2008, 07:51 PM   #3657
I setup my ice charger for .6 w/ peak detect set at 3mv to charge my receiver pack. It took around 1800 seconds and only took 63 mah of charge. This doesn't seem right.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-28-2008, 09:59 PM   #3658
s10dude's Avatar
try setting your peak higher.........
Old 05-29-2008, 05:57 AM   #3659
etgdpu's Avatar
Default New WC clutch
Hello
The information I have is that the only differences between the current and the new WC centax are:
1) clutch bell
2) all the pinions
3) the front bearing from 5x10x4 changes to 5x8x2.5
Therefore, the current spurs can be used.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 05-29-2008, 07:34 AM   #3660
dj apolaro's Avatar
Originally Posted by etgdpu View Post
Hello
1) clutch bell
2) all the pinions
I think the pinions do not work with the old gears.
DJ Apolaro
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
