Serpent 720
#3631
first gear 17/60
second 23/56
Best tire size for quals if traction is good and tire wear is down.
Rear 58.5
Front 57
#3632
front
1 hole piston 35 wt oil with new blue springs layed down
front sway bar soft (I did not use it at this race)
roll center pins in upper position
0 droop
37 front tires 58mm
30 grams of weight in bumper
2mm caster in front of arms
1.75 camber
-1 toe
rear
2 hole piston 35 wt oil with new orange springs 3rd hole up from bottom
2.3 sway bar soft and on the inner position on the arms
#3 roll center postion from the bottom
4 droop
40 and 42 rears (depending on traction) 59.5mm
3 camber camber link at its shortest and most angle
+2 toe
What new steering blocks are you talking about. We only have the ones that come in the 08 kit, I use the 0 degree. Serpent does not have any others that I know about. I am still talking to Paolo about the chicago race. Not sure if the civic body is ready for ship yet, but man if you like a lot of stable steering this body is great.
Hope this helps and if I missed anything just ask.
Regards,
DJ Apolaro
0 droop
37 front tires 58mm
1.75 camber
-1 toe
rear
4 droop
+2 toe
Regards,
DJ Apolaro
#3633
Hope this helps,
DJ Apolaro
#3634
Does anyone tried the CRF Serpent clutch conversion for 710/720
the spring look a lot ticker then the stock one or is better to stick to the original clutch weights/shoe and the 1.8mm spring ser#909518
Thanks in advance for all advices
#3637
I've been running a 750mAh NiMh pack and still enough for the entire main ( 45min).
#3638
i tryed the spring and didn't like it to hard...the 1.8 stock serpent spring work's much better ...imo...
#3639
#3643
#3644
#3645
