Serpent 720
Old 05-02-2008, 09:48 PM
  #3571
Will the 720 rear diff fit into the 710?
RoyU is offline
Old 05-02-2008, 09:56 PM
  #3572
Team Kamikaze's Avatar
710 has a different rear gear diff.
Team Kamikaze is offline
Old 05-03-2008, 02:23 AM
  #3573
Sow&Steady's Avatar
The insides are the same but make sure you get the right diff-case for the 710 because the number of teeth is different between the two.
Sow&Steady is offline
Old 05-03-2008, 07:00 AM
  #3574
s10dude's Avatar
Originally Posted by Serpent720 View Post
What type of glue do you use to glue the brake pads to the shoe?
CA glue.....or super glue to people...
s10dude is offline
Old 05-03-2008, 12:16 PM
  #3575
Serpent720's Avatar
TY!
Serpent720 is offline
Old 05-04-2008, 10:05 AM
  #3576
RevMaxx's Avatar
Originally Posted by dj apolaro View Post
Yellow shoe, stock weights, 1.8 spring, .6 to .7 gap and spring tighened 1.7 to 1.9.
I recommend tighening your spring to 1.5 to start and if you need more go to 1.7 or 1.8.
This clutch set-up is very good and consistent.
DJ Apolaro
when you mean tightening the spring to 1.5 or 1.7/1.8, is this the distance in mm from the tip of flywheel clutchnut to the pre-load adjusting nut or is this number of turns?
TIA...
RevMaxx is offline
Old 05-04-2008, 10:07 AM
  #3577
Sow&Steady's Avatar
TIA...
Usually that is quoted as the distance between the tip of the flywheel nut to the pre-load adjusting nut.
Old 05-04-2008, 06:16 PM
  #3578
dj apolaro's Avatar
TIA...
That is the amount of thread that should be showing. Yes from nut, not turns.
DJ Apolaro
dj apolaro is offline
Old 05-05-2008, 06:00 AM
  #3579
Jemmie's Avatar
Other question, is the wear of the steel pinion combo significant less compared to the alu pinions. And is the increased weight of the pinion a big disadvantage?
Jemmie is offline
Old 05-05-2008, 08:11 AM
  #3580
dj apolaro's Avatar
The steel ones last forever. No problem with the weight.
DJ Apolaro
Old 05-05-2008, 10:20 AM
  #3581
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
MMR driver Andrew Tq's and finishes second in the season opener 37th Heart Of America Series with his Mega powered Serpent 720.
ammdrew is offline
Old 05-05-2008, 10:36 AM
  #3582
dj apolaro's Avatar
Congrats........... Any pics of that fast beast.
DJ Apolaro
Old 05-05-2008, 11:54 AM
  #3583
Sow&Steady's Avatar
Well done! Like DJ says, any pics ... or videos?
Old 05-05-2008, 12:08 PM
  #3584
Sow&Steady's Avatar
... repeat post.
Old 05-05-2008, 12:35 PM
  #3585
ammdrew's Avatar
no pics looks like most ,Will see if we can come up with some, end of race we just wanted to get on the 400 mile drive home.
ammdrew is offline
