Old 04-30-2008, 07:00 AM   #3556
Racer Z's Avatar
Originally Posted by s10dude View Post
when measuring rear droop..do you use the front or rear ball? there is a 1mm difference in the 2.....?
Use the rear pivot. The same one you use to adjust track width!!
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 04-30-2008, 09:27 PM   #3557
s10dude's Avatar
thank's i was usuing the front one....
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-01-2008, 06:32 AM   #3558
shiston's Avatar
Hi,
Any talk about a 730 in the pipeline??????
shiston is offline   Reply With Quote
Old 05-01-2008, 10:02 AM   #3559
BURATIS-SPP's Avatar
hi paolo, dj and gianni,
How often do you guys change clutch-shoe(red)?, do guys change every qualifying? and a new one for the mains, or you keep it there as long as its working? One more thing, do guys use part no. 1388 for the thrust bearing with 6 ceramic balls or the the one with 10 balls? Is there any difference?
TY in advance
BURATIS-SPP is offline   Reply With Quote
Old 05-01-2008, 03:00 PM   #3560
Sow&Steady's Avatar
Originally Posted by shiston View Post
Hi,
The Worlds is later this year ... Kyosho is already coming with the Evo2, I'm sure Serpent and others are cooking things to be ready!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-01-2008, 06:16 PM   #3561
dj apolaro's Avatar
TY in advance
I use the shoe as long as it is good. For multiple races( I can use a shoe for about 2 hours or more). I just clean it with a very fine sand paper(300). As for the thrust bearing they both are good. I do not care which one I use. I have never had a thrust bearing problem. As long as the clutch is good, then they last.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-01-2008, 07:34 PM   #3562
ty dj
Old 05-01-2008, 08:33 PM   #3563
spurgear's Avatar
Send a message via MSN to spurgear
Originally Posted by Mike Schumacher View Post
HELP!!! Where can I buy 1 piece Centax-3 16/22T (#802525) or 16/23T (#802526) steel pinion gear? I looked around but no luck. I've tried Ashford, Bruckner, Stormer, Superior...
http://www.rc-union.com/product_info...ducts_id=11326
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 05-02-2008, 02:02 AM   #3564
rcabj's Avatar
Default centax spring tension
i know like has been mention above the default setting around 1.5 - 1.8.
out of curiosity , how much less ( i mean tension less than the above ) has anyone here gone to with their setup , or 1.5 is the min everyone uses...thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-02-2008, 06:27 AM   #3565
Default rear bulkhead
do you guys get problem in rear bulkgead of getting loose.
do you have any solution on it?
Johny is offline   Reply With Quote
Old 05-02-2008, 06:34 AM   #3566
[QUOTE=rcabj;4407588]i know like has been mention above the default setting around 1.5 - 1.8.
It really depends on what type of track you are running. If the trrack has no grip at all you can even run lower than the base setting. However, if you are running on a high grip track, then you can may try even tighter. You have to feel the car by holding it down and applying throtle on it. it should then feel very hard to drive when you are racing. Or else you timng will be off.
Old 05-02-2008, 08:29 AM   #3567
dj apolaro's Avatar
No, The key is not to over tighten them when they are new.
DJ Apolaro
Old 05-02-2008, 10:23 AM   #3568
Serpent720's Avatar
What type of glue do you use to glue the brake pads to the shoe?
Serpent720 is offline   Reply With Quote
Old 05-02-2008, 11:04 AM   #3569
What would be a good gearing for a red dot evo 3 w/ 2607 pipe for 301 raceway? I'm running 17/23 61/55. Thanks in advance.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-02-2008, 12:13 PM   #3570
Team Kamikaze's Avatar
I suggest stay the same on the pinions but switch to 56 on your 2nd gear spur. 17/23, 61/56.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
