Old 04-18-2008, 12:25 PM   #3526
Originally Posted by Manu_05' View Post
Thanks for you answer Paolo!
And what do you change on your setup when the track is wet ?
Sorry, but we don't run on wet tracks in USA, so i have no experience
Paolo M is offline   Reply With Quote
Old 04-21-2008, 04:18 AM   #3527
It as nice to see Serpent on www.rctvlive.com Michael Salven's interview was good. Got to see Paolo too!
Congrats Team Serpent!
Ginsu is offline   Reply With Quote
Old 04-21-2008, 07:18 PM   #3528
I just won a auction off ebay for 5 sets of used serpent 720 shock springs front and rear. I tried to Google for a spring rate chart but couldn’t find one is there one out there that shows what color are what lbs??
j
John Q is offline   Reply With Quote
Old 04-21-2008, 07:27 PM   #3529
LOW ET's Avatar
Trader Rating: 97 (100%+)
j
there's one some pages back, or it's in the 960 thread.
LOW ET is online now   Reply With Quote
Old 04-22-2008, 11:07 AM   #3530
oze
j
Here it is:
oze is offline   Reply With Quote
Old 04-22-2008, 06:52 PM   #3531
s10dude's Avatar
aaah....thank's for the pdf file..i can use it too......
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 04-24-2008, 06:01 AM   #3532
etgdpu's Avatar
Default Setup book
Hello all,
I would appreciate if you clarified the following question.
In an old Serpent set up book and in an old Hudy setup book I read the following effects of the fron anti roll bar adjustment:
Effects of Front Anti-Roll Bar Adjustment
Stiffer
• Less chassis roll.
• Decreases front traction.
• Increases rear traction.
• Reduces off-power steering at corner entry (increases understeer).
• Quicker steering response.
Softer
• More chassis roll.
• Increases front traction.
• Decreases rear traction.
• Increases off-power steering (may cause oversteer).
While in the newer serpent 720'08 setup book and in the new XRAY NT1 setup book I read the following:
Effects of Front Anti-roll Bar Adjustment
Softer
• Increases chassis roll
• Increases front grip (decreases rear grip)
• Decreases off-power steering at corner
entry
• Slower steering response
Stiffer
• Decreases chassis roll
• Decreases front grip (increases rear grip)
• Increases off-power steering at corner entry
It seems that there is a contrudiction regarding the "off power steering at corner entry". The old books say that the softer anti roll bar increases it, while the newer books say that the stiffer anti roll bar increases it.
What is the correct?
BTW, my personal experience is that the softer anti roll bar increases it.
Thanks in advance
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 04-25-2008, 04:37 PM   #3533
noelpcs78's Avatar
Originally Posted by Paolo M View Post
my set-up
FRONT
3 hole 40wt with old purple spring bottom position
front sway disconected
solid axel front
roll center medium position
0.5 droop
40 tire shoe 58mm
with the chassis brass (803207)
caster 3mm front arms
2.1 camber
1.5 toe out total
REAR
3 hole 40wt yellow spring 2 position from bottom
sway bar soft 2.3mm outside position on arms
#2 position roll center from bottom
42 tire shoe 59mm
4 droop
3.5 camber
camber link long, lower position in the uprigth
2 toe in
diff 30.000
East Civic mounted on premarked holes
Congrats Paolo on your recent win.
One question, can I follow your set up using a mazda body. my local track here in CA is low to medium, not as technical, and I ran the 720 08 version.
I havent tried disconnecting the front sway bars but certainly will.
noelpcs78 is offline   Reply With Quote
Old 04-25-2008, 05:33 PM   #3534
good luck
ciao
gianni
serpentmaster is offline   Reply With Quote
Old 04-28-2008, 10:42 AM   #3535
Team Kamikaze's Avatar
Of course you can follow Paolo's set up, why not? now after copying it, then you will need to copy his driving skills too
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-28-2008, 12:31 PM   #3536
noelpcs78's Avatar
I hope i can, i always watch his winternats win I got from youtube....
Old 04-28-2008, 12:42 PM   #3537
Trader Rating: 16 (100%+)
Where is the link to download his driving skill? If you have DJ's, please share as well....
My 720 is missing the 2 5x10 bearing for the Centex 3...any idea will Serpent USA can send them over..? Or at least what parts number for those two 5x10 bearings...? Thanks guys
Old 04-28-2008, 01:14 PM   #3538
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
you can get all the part numbers here
http://www.serpent.com/file.php?FileID=4718
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 04-28-2008, 03:57 PM   #3539
Dreddlox's Avatar
Part #1315 ballbearings 5x10x4 (2)
Dreddlox is offline   Reply With Quote
Old 04-28-2008, 04:35 PM   #3540
Default 2 speed problem
Hi guys,
I have smal problem (big) , my gears don't less longer in my serpent 720 . I notice that the pinion and the gear (news) don't match properly (17/61 or 60) .
Do someone knows about this ? they less no longer than 5 minutes (I ensure that the gap is ok).
ajsilva is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
