Old 04-16-2008, 04:39 PM   #3511
my set-up
FRONT
3 hole 40wt with old purple spring bottom position
front sway disconected
solid axel front
roll center medium position
0.5 droop
40 tire shoe 58mm
with the chassis brass (803207)
caster 3mm front arms
2.1 camber
1.5 toe out total
REAR
3 hole 40wt yellow spring 2 position from bottom
sway bar soft 2.3mm outside position on arms
#2 position roll center from bottom
42 tire shoe 59mm
4 droop
3.5 camber
camber link long, lower position in the uprigth
2 toe in
diff 30.000
East Civic mounted on premarked holes
Paolo M is offline   Reply With Quote
Old 04-16-2008, 04:42 PM   #3512
Derby Bros Racing's Avatar
Paolo you got PM
Derby Bros Racing is offline   Reply With Quote
Old 04-16-2008, 04:43 PM   #3513
Originally Posted by ck960 View Post
Hi DJ, Gianni,
was wondering does it make alot off difference between adding weight inside the bumper and using the chassis brass??
i have tried using the chassis brass, it help on traction roll but rob abit of steering...
how do u mount the front weight?? double side tape?? any pic on the added weight would be nice... thanks in advance
cheers,
ck lee
I will answer for them. Yes it makes a difference. When you use the chassis plate, you are not only adding the weigth, but also modyfing the fexion of the chassis in that area. I always run with the plate now (any condition) i just play with thge setup to get the steering. Try the setup i posted. I run the car like this always. I just change camber, caster and toe depending on track. Is a really god balance and starting point.
Front weigths are normally mounted inside the foam bumper. DJ is really good at this process. He makes the hole in the foam and then place the led inside with glue.
Old 04-16-2008, 05:48 PM   #3514
ceaz's Avatar
hey paolo, congrats on ur win. Also what ride height were u using for the set-up above...
Serpent 720
Fanatic Remote Racerz
Controlfreakz.com
Sponsored by: my checkbook
ceaz is offline   Reply With Quote
Old 04-16-2008, 06:50 PM   #3515
Thanks man........
Opss i forgot....
6.5mm rear and 5mm front
Old 04-17-2008, 01:17 AM   #3516
Originally Posted by Paolo M View Post
Thanks man........
Opss i forgot....
Hi Paolo!
Why do you have a big difference between front and rear ? I put always 5mm in front and 5.5mm rear
Team Awesomatix - WTF - Thunder Power - Mikovic Body Painting - ToniSport - PRT Electronics
Manu_05' is offline   Reply With Quote
Old 04-17-2008, 03:20 AM   #3517
Thanks Paolo,
i'll definetely try your setup on next race or practice
FYI i'm using the option LCG chassis with the chassis plate, not updated to 08 chassis yet.
our local track here mostly the traction low and do not have additive to the track. so i think the LCG chassis with weight will suit me more or do u recomend the new 08 chassis which is stiffer??
thanks again...
ck960 is offline   Reply With Quote
Old 04-17-2008, 03:42 AM   #3518
kitracer's Avatar
Thanks Paolo,
thanks again...
CK, looks like you getting ready for FEMCA already
For low traction, dont switch to 08 chassis. Keep the LCG.
kitracer is offline   Reply With Quote
Old 04-17-2008, 05:18 AM   #3519
hey chris,
how r u doing? yeah i just hope i can qualify for the FEMCA race cos till now the slot for local is only 10 racer for each class also not confirm
u going for the FUTABA cup in Jakartar next month?? i'll be there
hope i'll see u in august FEMCA race
Old 04-17-2008, 06:19 AM   #3520
Pedro_Speedy's Avatar
Pedro
The New Roc 360 V 2.0
Sponsored by.RC America-Xray-Hudy- Hot Race Tyres- GQ Racing Tires- Sweep Racing tires- Fantom racing- SpeedMerchant- Boca Bearings- TQ Wires- Maxy's Pro Racing Fuel - Maxy's Modified Engine-Larcher Paintworks- Brooklyn Hobby.
Pedro_Speedy is offline   Reply With Quote
Old 04-17-2008, 07:07 PM   #3521
Originally Posted by Manu_05' View Post
Hi Paolo!
I like to have my car to pivot on the nnose a lot (this is a must when you run solid axle in the front) so i like my car to trsnafer a lot of weigth in the front wheels off throttle
Old 04-17-2008, 07:09 PM   #3522
Thanks Paolo,
thanks again...
We all drive the LCG chassis. The 08 is the std chassis with the option to install or remove the front brass plate.
On high grip conditions, flat track, 08 chassis works really good. I will reccomend in your driving conditions to use the LCG
Old 04-17-2008, 11:17 PM   #3523
kitracer's Avatar
Thanks for the details. You must have really good steering off throttle with this setting and the no fron roll bar..
I will try your setting this week( if not Hurricane!).
Im still running the 06 car with LCG, will switch to 08 once I get the time to switch over the electronics.
hey chris,
Going to Kawahara/ Novarossi Cup in Japan on the same week so can't make it to Jakartar. Have fun and kick some asiii
If you can't make to the race, I could hire you be my mechanic...
at least you get pc of the action.... I am so kind!!!
Old 04-18-2008, 09:28 AM   #3524
Paolo, thanks
Chris, i'll try my best to be there for u,even i race or no race
good luck for u in japan...
Old 04-18-2008, 12:23 PM   #3525
Thanks for you answer Paolo!
And what do you change on your setup when the track is wet ?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
