Old 04-15-2008, 10:50 AM   #3496
dj apolaro's Avatar
Well this weekend we ran the US open and my car was great. I must have had one of the fastest cars on the track. The 720 was the fast car of the event. Paolo and I had very good cars and people took notice. I ran my basic set-up and made only a few changes. Some minor camber and caster changes and the rest was great. I built a new car/kit and did not know what to expect. But within 3 tanks my car was on pace to be the fastest for the weekend. I would like to thank Paolo and all the Serpent crew for the hard work we have been doing. I feel we work well as a team when we get to the tracks and push each other to perform. I hope I was able to help all the serpent drivers at the event that needed it and look foward to the next event. I think my next race is june at the 301 race, so till then.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 04-15-2008, 10:59 AM   #3497
Trader Rating: 16 (100%+)
Congrat Paolo and DJ....nice showing. If possible, can you guys share the setting @ Open Nat? I am gathering some setup that is similar to the LHR and will start testing setups before the Byron race...
DJ and Paolo....after the 301, you guys are coming to Byron race....you know that is going to happen....(right?)
P.S...are you guys using the new front steering block for 720? Are the Civic body ready to ship @ Serpent USA? I need to gather a list including the Xceed Lipo and will phone Serpent USA to place order...thanks.
Old 04-15-2008, 11:07 AM   #3498
I don't believe the Serpent body is out yet. The best body to us at the present time is the Blitz Altis 2.3. Works great on the 720's as well as the other cars as proven is the worlds warmup. I love my 720 and I know the body helps, but unfortunately when you get older as I am, I do admit, I keep needing more and more help!!!
TM America is offline   Reply With Quote
Old 04-15-2008, 11:17 AM   #3499
Solara: DJ as always give really good support on this thread, so i am sure he will post his setup soon. I will do the same. About the Byron Race, not decided yet but therte is a really good chance we go. We use the new steering blocks. I personally like the "0" deg better. Al lthe xceed stuff is in stock. The bodies with the embossed number are on the way. Maybe this Friday are ready to ship. I Open another thread for this body.
TM America: How are yoyu sir? You are rigth, Body is not out yet. DJ run the Altis at the WNats and he was really pleased. There are many products out there at the moment that work great. Is about giving more choices to the consumers and expanding the line of products
Paolo M is offline   Reply With Quote
Old 04-15-2008, 11:18 AM   #3500
Trader Rating: 68 (100%+)
Send a message via AIM to joey
i almost got my kit finished is there any option parts this car needs out of the box? i have the older version of the kit not the 08..
=Joe Wright=
joey is offline   Reply With Quote
Old 04-15-2008, 11:23 AM   #3501
dj apolaro's Avatar
front
1 hole piston 35 wt oil with new blue springs layed down
front sway bar soft (I did not use it at this race)
roll center pins in upper position
0 droop
37 front tires 58mm
30 grams of weight in bumper
2mm caster in front of arms
1.75 camber
-1 toe
rear
2 hole piston 35 wt oil with new orange springs 3rd hole up from bottom
2.3 sway bar soft and on the inner position on the arms
#3 roll center postion from the bottom
4 droop
40 and 42 rears (depending on traction) 59.5mm
3 camber camber link at its shortest and most angle
+2 toe
What new steering blocks are you talking about. We only have the ones that come in the 08 kit, I use the 0 degree. Serpent does not have any others that I know about. I am still talking to Paolo about the chicago race. Not sure if the civic body is ready for ship yet, but man if you like a lot of stable steering this body is great.
Hope this helps and if I missed anything just ask.
Regards,
DJ Apolaro
Old 04-15-2008, 11:31 AM   #3502
TeamButter's Avatar
Send a message via AIM to TeamButter
Wanted to thank Serpent USA and the whole Serpent crew Paolo.M (don't douche me!), DJ Apolaro (I don't understand how you are explaining it...i'm tired), Gianni.G (Pana, dame el putty!), Roniel.R (you're a 5) for all of their help with the 720 during my first nitro race, the US Open. The car was fast, consistent and stable. I hope to continue learning about nitro racing and I look forward to more of it!! Capitol classic here I come!!
Thank you guys!!!
Butter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 04-15-2008, 11:59 AM   #3503
Thank you guys!!!
Butter
i need my putty lololololo
serpentmaster is offline   Reply With Quote
Old 04-15-2008, 12:01 PM   #3504
Thanks Paolo and DJ for the setup...looking forward to see you guys @ the Byron or the Chicago races....now, I need to wrench the 720 after all the EP races.
Old 04-15-2008, 12:18 PM   #3505
my set-up
FRONT
1 hole 35wt with old blue spring 2 position from bottom
front sway bar soft and flat
solid axel front
roll center medium position
0 droop
40 tire shoe 58mm (for 30min semi 59.5mm)
with the chassis brass (803207)
caster 4mm front arms
1.9 camber
2 toe out
REAR
2 hole 35wt yelow spring 2 position from bottom
sway bar soft 2.3mm and 3mm link more in
sway bar inner position on the arms
#2 position roll center from bottom
42 tire shoe 59mm (for 30 min semi 61mm)
4 droop
3.5 camber
camber link long
2 toe in
diff 30.000
ciao
gianni
Old 04-15-2008, 09:45 PM   #3506
BURATIS-SPP's Avatar
Default follow
dj,
1. What were your ride heights (front and back) with 58mm and 59.5mm during qual?
2. what diff oil were you using for the rear?
3. were you using L27 orange for the back or just L23 orange?
Gianni,
1. What were your ride heights (front and back) on your setup?
ty guys
BURATIS-SPP is offline   Reply With Quote
Old 04-16-2008, 05:54 AM   #3507
Originally Posted by BURATIS-SPP View Post
dj,
Gianni,
ty guys
hi buratis-ssp
with tire 58mm front 4.5 ride height
and rear 59mm 5.5 ride height
ciao
gianni
Old 04-16-2008, 08:15 AM   #3508
dj apolaro's Avatar
dj,
Gianni,
ty guys
front 5 rear 6.5
30,000 diff oil
23mm in front and 27mm in rear
Old 04-16-2008, 08:26 AM   #3509
thanks for the reply dj and gianni!!!
Old 04-16-2008, 08:38 AM   #3510
Default weight up front
Hi DJ, Gianni,
was wondering does it make alot off difference between adding weight inside the bumper and using the chassis brass??
i have tried using the chassis brass, it help on traction roll but rob abit of steering...
how do u mount the front weight?? double side tape?? any pic on the added weight would be nice... thanks in advance
cheers,
ck lee
ck960 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
