Old 02-12-2008, 04:32 PM   #3361
captian's Avatar
Originally Posted by LOW ET View Post
does anyone know what are the effects of different length fuel lines? like the length of the line from the pipe to the tank? the tank to the carb? i know run time increases with longer lines do to there being more fuel on board, but any other effects? what about short lines? when running my fuel lines like the manual says, they'll be very short from what i'm used to seeing. i was always told to coil up the line from the pipe to the tank.
short line makes pressure high and longer lines lowers pressure . to both the pipe and carb .
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 02-12-2008, 04:33 PM   #3362
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
yes thats what i was saying just shorten the carb line a little so it almost hugs the filter and when you run the car try it with and without the filter on the carb line you may not need it. Only time you need it is if your having trouble making 5 minutes run on tank.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-12-2008, 04:35 PM   #3363
Hey captain got snow tires on my 720 meet you at Floyd
Old 02-12-2008, 04:42 PM   #3364
captian's Avatar
save a set for my rear i will put ski's in the front need to hold that in side line i will bring a spare ski hat for your engines cooling head so at the engines stay warm
Old 02-12-2008, 04:55 PM   #3365
LOW ET's Avatar
Trader Rating: 97 (100%+)
i take it you guys are getting blasted with snow too?
LOW ET is offline   Reply With Quote
Old 02-12-2008, 05:02 PM   #3366
yeah but I think you getting more
Old 02-12-2008, 05:03 PM   #3367
LOW ET's Avatar
haha, yes it sucks right now.
Old 02-12-2008, 10:07 PM   #3368
We got blue skies and sunshine
RoyU is offline   Reply With Quote
Old 02-13-2008, 03:33 AM   #3369
Default 803178 - 2 Speed Shaft SPP 720
Hi everybody,
Just replace the new SPP shaft yesterday. Like it very much. The problem is that the E-Clip thread is too little for it to be placed in. Has anybody having the same problem.
Regards
MorShah is offline   Reply With Quote
Old 02-13-2008, 05:02 AM   #3370
LOW ET's Avatar
what starter box does eveyone use to start their 720's? i thought i'd be able to use my associated starter box but it will need to be modified for use with the 720.
Old 02-14-2008, 11:50 AM   #3371
Associated. LIke the Serpent better, lighter, smaller.
Old 02-14-2008, 01:05 PM   #3372
if you can get the older serpent box(black+purple, or grey+black) your good thats the best box for your serpent because you car comes with the plates for the car to sit on perfectly.
Old 02-15-2008, 09:50 AM   #3373
rcpanama's Avatar
Default I Degree Steering Block
Hi, I have at the moment install in my 720 the steering block 1degr L+R 803212, our club is using a Parking Loot track, low to Med traction, very technical, what will be the difference of using the 1 degree or the 0 degree Steering Block.
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 02-15-2008, 10:15 AM   #3374
raychan's Avatar
Default RE: 1 degree blocks
RCPANAMA
1 degree L/R steering blocks gives u a smoother grip in corners at low - medium traction surfaces whereas 0 degree blocks works better at medium traction sufaces. In general, 1 degree blocks are more versatile coz u can switch the orientation (swap L/R) and gives u better grip at high traction surfaces. 1 degree blocks can be quite aggresive if you are not use to it and requires a little training to get it right. I find the 0 degree blocks easier to drive. Hope this helps...
Cheers,
Raymond Chan
raychan is offline   Reply With Quote
Old 02-15-2008, 10:33 AM   #3375
rcpanama's Avatar
Cheers,
Raymond Chan
Excellent this really helps me to understand the difference of the two, now I get why it was a little difficulty when I change to the 1 degree.
RCPANAMA
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
