Old 02-11-2008, 08:21 PM   #3346
rcabj's Avatar
Originally Posted by dj apolaro View Post
Use Gap at .7
tighten nut to 1.5 to start
use serpent 1.8 spring from 1/8 scale
DJ Apolaro
for a low traction track, do i decrease the spring nut tension ?
also i am having rear diff leakage , seems like the silicone is coming out through the right cup. what do i need to do to rectify it..? thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-11-2008, 08:42 PM   #3347
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
no loosen it a bit. As for diff leakage you my have over tightened the four screws and crushed the o-ring.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-11-2008, 08:48 PM   #3348
rcabj's Avatar
so replacing the o ring would solve the leakage right..
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 02-11-2008, 08:50 PM   #3349
Default Spring what to get?
I'm runing 720 08. Want to know what type of springs I should keep in my pit obx thanks
ioxqq is offline   Reply With Quote
Old 02-11-2008, 09:08 PM   #3350
just remember 2 things dont over fill the diff or over tighten the screws
Old 02-11-2008, 09:12 PM   #3351
If you are using the new springs then for the rear med. soft yellow , fronts green,grey,and black.
Old 02-11-2008, 09:34 PM   #3352
thanks, L23 is for front or L27 for front?
Old 02-11-2008, 09:36 PM   #3353
correct.
Old 02-11-2008, 11:25 PM   #3354
soc123_au's Avatar
R/C Tech Charter Subscriber
L23 are for the 720 & L27 is for the rear of the 960. I use L27 in the rear of the 720 sometimes as well.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 02-12-2008, 08:45 AM   #3355
rcpanama's Avatar
Default 1 or 0 Degree Steering Block
Hi, I have at the moment install in my 720 the steering block 1degr L+R 803212, our club is using a Parking Loot track, low to Med traction, very technical, what will be the difference of using the 1 degree or the 0 degree Steering Block.
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 02-12-2008, 10:11 AM   #3356
yes l23 is for the front and l27 for the rear.
Old 02-12-2008, 10:31 AM   #3357
DS Motorsport's Avatar
The l stands for length and 23 and 27 stand for the lenght in mm.
So pretty simple to remember because you never use longer springs in the front then the rear.
DS Motorsport is offline   Reply With Quote
Old 02-12-2008, 04:09 PM   #3358
LOW ET's Avatar
Trader Rating: 97 (100%+)
does anyone know what are the effects of different length fuel lines? like the length of the line from the pipe to the tank? the tank to the carb? i know run time increases with longer lines do to there being more fuel on board, but any other effects? what about short lines? when running my fuel lines like the manual says, they'll be very short from what i'm used to seeing. i was always told to coil up the line from the pipe to the tank.
LOW ET is offline   Reply With Quote
Old 02-12-2008, 04:17 PM   #3359
the way you say that you have it from pipe to tank is fine, as for tank to carb dont go straight back angle it around the filter
Old 02-12-2008, 04:26 PM   #3360
LOW ET's Avatar
here's what i got now
any suggestions?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
