Old 02-08-2008, 12:11 PM   #3331
spurgear's Avatar
Send a message via MSN to spurgear
I set the clutch gap to the recommended 0.8 for the novarossi engines. However when i run on my track. I notice it takes a while for the car to pickup. I drove another top drivers car a NT1 and its super sensitive. As i hit gas it moves through the turns with low power just right. Also when im taking off from a standstill. I have to atleast pull throttle twice for it starts to move. I have been running car like that ever since.
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 02-08-2008, 12:36 PM   #3332
petevette's Avatar
Send a message via Yahoo to petevette
Hi, I understand the Winternats C-A mains will take place on Saturday. Anyone have an idea of what time the races will end or venture to take an educated guess. I want to drop by and spectate, but have a small window of opportunity.
petevette is offline   Reply With Quote
Old 02-08-2008, 12:43 PM   #3333
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
try to tighten the clutch spring a little, remember a little does alot so go in a little at a time, hope this helps.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-08-2008, 12:48 PM   #3334
Spurgear:
I kind of dificult to answer your question, becuase there are some other factors to consider, like servo speed and linkage. Also spring setting and engine tunning.
You should first verify the servo neutral position and its speed.
Edgar Millenium is offline   Reply With Quote
Old 02-08-2008, 01:02 PM   #3335
also which shoe are you using yellow or black.
Old 02-08-2008, 01:08 PM   #3336
How much is a "little"?
RoyU is offline   Reply With Quote
Old 02-08-2008, 01:17 PM   #3337
less than half a turn then if no noticeable difference turn it a little more, so that you can easily go back if needed and you didn't lose your original starting point,hope this helps.
Old 02-08-2008, 01:41 PM   #3338
Derby Bros Racing's Avatar
It sounds like your clutch is too tight. I would loosen it a little bit until it grabs a little quicker. The recommended 0.8 for Novarossi is a good starting point, however, in my case I usually end up with 0.6 to 0.7. A quarter turn on the clutch nut is about a 0.1 difference.
Derby Bros Racing is offline   Reply With Quote
Old 02-08-2008, 03:18 PM   #3339
Look at the set up booklet that came with the car check pg. 31
Old 02-09-2008, 02:04 AM   #3340
flylow's Avatar
S720'08
R/C Tech Lover!!
flylow is offline   Reply With Quote
Old 02-09-2008, 08:04 PM   #3341
s10dude's Avatar
S720-08........
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 02-09-2008, 08:10 PM   #3342
Send a message via MSN to Qlone
Thumbs down
Got me a 720-08 today, to replace my aging 720 :P . Nah... wanted a lot of spares and things to experiment with and found out a new car was cheaper than buying all parts separately.
Anyway... Serpent's QA doesn't seem to be that great again, with my kit missing the set screws for the rear downstops and the screws for the brass chassis plate insert. For the rest the car looks nice and I look forward to driving it...
Qlone is offline   Reply With Quote
Old 02-09-2008, 08:11 PM   #3343
dj apolaro's Avatar
Use Gap at .7
tighten nut to 1.5 to start
use serpent 1.8 spring from 1/8 scale
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 02-09-2008, 08:17 PM   #3344
get to work DJ you ready...
Old 02-09-2008, 09:14 PM   #3345
LOW ET's Avatar
Trader Rating: 97 (100%+)
does your receiver packs hit the fuel tank? are you doing anything special to mount it or make clearance. i have a nimh receiver pack for a 720 but the packs heat shrink hits the tank, i can get everything together but wasn't sure if it's normal.
do you guys use an external fuel filter?
and for those using a radio with a failsafe built in, are you using a regular failsafe in conjunction with the radio's?
LOW ET is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
