Old 02-04-2008, 08:30 PM   #3301
s10dude's Avatar
for me the added weight makes car push in the turn....work's better with nothing in that area..
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 02-05-2008, 12:09 PM   #3302
LOW ET's Avatar
Trader Rating: 97 (100%+)
anyone have pictures of how your receivers are mounted? do you guys even use the receiver cover? i have my receiver mounted but there's no way the cover will go on without a visit from my dremel.
LOW ET is offline   Reply With Quote
Old 02-05-2008, 12:28 PM   #3303
dj apolaro's Avatar
I do not use the cover.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 02-05-2008, 12:35 PM   #3304
LOW ET's Avatar
here's another quick question. on the servo saver i have two different blocks the screws go through, with the holes in slightly different places. which block should i use and what setting is best?
Old 02-05-2008, 12:44 PM   #3305
dj apolaro's Avatar
I use mine in the longer and most outer position. I gives more steering.
DJ Apolaro
Old 02-05-2008, 01:46 PM   #3306
LOW ET's Avatar
how are you guys getting the gears on the brake pulley one way. i can get everything together but i cant see the e-clip groove. the stock shaft measures 14.88mm from the pin hole to the e-clip groove and the one way shaft measures 13.83mm from the pin hole to the e-clip groove. do i have a bad shaft , or am i missing something?
Old 02-05-2008, 04:26 PM   #3307
s10dude's Avatar
i had to use a dremel on my receiver cover...i have the futaba 2.4ghz and it's got the little lump at bottom.plus i cut out space so i could face receiver outwards so i could plug everything in ...including battery for on/off
Old 02-05-2008, 08:44 PM   #3308
raychan's Avatar
Default RE: Mistake
Originally Posted by Serpent-Dan View Post
If you mean the brass plate up front, its to stiffen up the chassis when less front end grip is needed when you don't have it on the front end flexes more for more steering. Hope this helps..
Nope, the brass front plate is to add on weight and gives u more steering and reduces steering oversnap corner entry. The carbon stiffener works otherwise.
Cheers,
Raymond Chan
raychan is offline   Reply With Quote
Old 02-05-2008, 08:58 PM   #3309
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
nope they both stiffen the front the brass adds more weight than the carbon plate but they both stiffen the front..hence the need to screw in the plate, if it didn't add to the stiffness then they would have not allowed you to add the plate brass or carbon. GET IT> GOOD
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-05-2008, 09:10 PM   #3310
raychan's Avatar
Default RE: Got you good
Oh yes I got you good my fren... It's obvious both brass and carbon stiffens the LCG plate but only with different effects as I stressed. Without both will definitely flexes the chasis more but u tend to lose consistencies as the corner entry is always unpredictable.
Cheers
Old 02-05-2008, 09:14 PM   #3311
Cool Rossi decals on your car pic
Old 02-05-2008, 09:20 PM   #3312
raychan's Avatar
Default RE: Rossi
Thanks... you like rossi too. He's in Malaysia for testing at Sepang track since yesterday and top the timesheets at 2'00.300 a sec faster than any other riders. Looks like his new pneumatic valve M1 engine helps.
Cheers,
Old 02-05-2008, 09:21 PM   #3313
Not to mention the Bridgestone tires too
Old 02-05-2008, 09:25 PM   #3314
raychan's Avatar
Default RE: Tyres
Oh yes.. Very good. Definitely a good season to watch. Who's ur fav rider. Don't tell me its Hayden coz my wife loves him and that drives me crazy. Hate him!!!
Cheers
Old 02-05-2008, 09:29 PM   #3315
Hands down Vale but then comes Nicky remember he's riding a bike designed around little Pedrosa the bike ain't made for him but he is the only one who is developing the bike like Rossi used to do when he rode for Honda. Pedrosa can give enough feed back on the bike so they can know which direction it needs to go.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
