Old 01-28-2008, 02:14 AM   #3286
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
for you sacramento/ SF guys... I have a bunch of serpent 720/710 drivetrain parts (belts, gears, clutch and two speed parts up the wazoo) in the classifieds section.. check it out..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-28-2008, 02:48 AM   #3287
rx7ttlm's Avatar
cheers
Old 01-30-2008, 11:56 PM   #3288
fly_wheel's Avatar
i just got myself a new front gear diff for my 720, will have to replace the diff oil (currently is 50,000cwt) to 30,000cwt as my rear is using 20,000cwt... will try 35,000 shocks oil + 2 holes piston on all for shocks n another set on 3 holes piston with same shocks oil... n will try wat is the out come...
fly_wheel is offline   Reply With Quote
Old 02-01-2008, 07:00 AM   #3289
LOW ET's Avatar
Trader Rating: 97 (100%+)
so when is the best time to use the brake pulley one way or is it good in all situations?
LOW ET is offline   Reply With Quote
Old 02-01-2008, 07:05 AM   #3290
typer's Avatar
Originally Posted by LOW ET View Post
for those with a 720 '08 or even a 720 '07, does the kit come with the front one way and solid locking diff parts? on the serpent website it reads:
Gear Differentials
The supplied gear differentials give smooth differential action and high durability, and gear slippage is non-existent due to the geared design. Performance and tuning characteristics are easily adjusted via gear oils of different thicknesses.
As an added extra, the Serpent 720 '08 comes with the previously optional front one way system as well the one way lock set to make it into a solid axle, ensuring your car will be ready for all conditions.
well i'm trying to put my 720 '08 kit together and first thing i notice is i do not have the one way or solid diff parts. are they in another bag besides the diff parts bag? i looked through the other bags briefly but i did not see anything that resembles those parts. does anyone have info on what bag they're supposed to be in?
yes it comes with the kit
typer is offline   Reply With Quote
Old 02-02-2008, 01:49 AM   #3291
fly_wheel's Avatar
both 720 07 n 08 came with the front one way, front lock pins n front gear diff... extra in 08 is the aluminium radio tray 'X' bracket, monoblock engine mount n chasis with front stiffener insert (the front looks like the SPP lcg chasis)... also the optional front hub n new springs... but dunno wat's the colour code of the new springs included...
what's the functional differents of the new front hubs, the 1 degree, 0 degree n the old one...???
the new chasis should improve handling but letting driver to alter the stiffness of the front chasis but it does seems as weaker part of the chasis if involve in strong impact/accident... well at least that's the chances for most beginner ... but for better driver, the chasis is an advantage... but the LCG chasis is even better, lighter n when combine with LCG monoblock n smaller flywheel, the car should handle much better...!!! but the risk of it, 'don't crash'...
Old 02-02-2008, 06:34 AM   #3292
s10dude's Avatar
mine came w/ purple and red....and the spring's are the shorter front and longer rear...
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 02-03-2008, 08:07 AM   #3293
Sow&Steady's Avatar
Been seeing Mark Green working on his 720-08 the last couple of days. He's preparing for the WinterNats as well as Round1 of the BRCA Nationals at my local track.
He has sent me some info/tips to share with everyone including his latest setup. go to 3hobby.net to find out more ...
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 02-03-2008, 09:01 PM   #3294
rcabj's Avatar
Default front brass or carbon tray
guys....anybody can tell me when r these "trays" r used with the lcg chasis...thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-03-2008, 09:05 PM   #3295
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
If you mean the brass plate up front, its to stiffen up the chassis when less front end grip is needed when you don't have it on the front end flexes more for more steering. Hope this helps..
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-03-2008, 11:02 PM   #3296
rcabj's Avatar
if i understand u correctly , :
with the plate attached front grip is reduce
wihout it will increase front grip
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 02-04-2008, 09:48 AM   #3297
roadrage's Avatar
Trader Rating: 14 (100%+)
the carbon fiber plate stiffins the front to reduce stearing. the brass plate in the front helps give to car more dive into the corner because of more weight
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 02-04-2008, 11:17 AM   #3298
yes and the plate adds some weight in the front
Old 02-04-2008, 12:17 PM   #3299
LOW ET's Avatar
what degree are the stock steering blocks in the 720 '08 kit? i have the zero degree, 1 degree, and stock.
Old 02-04-2008, 01:11 PM   #3300
Team Kamikaze's Avatar
O is Stock.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
